![]() | Home > General > Car laid up |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5138
I wouldn’t worry about those things.
| DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2025
Gearbox in P. EPB off.
EPB off
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5154
Yeah, used to work abroad a lot so car parked up 3 months at a time, left in normal ride, height, EBC off and Ctek charger connected, never had any issues.
How do you get round the EPB automatically engaging as used to happen with both my 2007 L320 TDV8 and my 2015.5 SDv6? I never had a problem with them disengaging after 3-4 months , yes they would be sticky but they never jammed on, same with the L322 FF’s and both Evoques I’ve owned, the EPB was never an issue and the cars all lived out on the drive and often for the whole winter. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
You deactivate auto engagement for the EPB in the CCF files.
| insiorc Member Since: 17 Jul 2016 Location: Scotland Posts: 533
Initially my auto EPB was off so I turned it on in the CCF as I'd never rely on the park pawl only, especially with the high winds up so probably rocking the RRS back and fore. Now if I manually move to Park the EPB does not automatically come on, only if shutting down the engine in a gear including R. This may have changed with newer ones as there is no way of preventing my wife's Evoque EPB applying, it happens regardless of what the gear selector is on but I haven't been into the CCF on it. 13MY Range Rover Sport Autobiography SDV6 - mine 14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's 99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite Last edited by insiorc on Sat Apr 04 2020 10:11am. Edited 1 time in total |
Unsure of the CCF settings, but you can put the newer cars into EPB maintenance mode to prevent the EPB applying when ign off |
The suspension being air won't be affected, I was working a month on/off so the EPB could be left on the whole month with no issue's, I'm more concerned about brake disk corrosion as per this thread - https://www.rrsport.co.uk/forum/topic56006.html 13MY Range Rover Sport Autobiography SDV6 - mine 14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's 99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite |
| stevoc Member Since: 08 Apr 2018 Location: Cumbernauld Posts: 22
Hey disco mikey. My car is parked too far away from my house for a trickle charger. Is there any alternative to that? Would disconnecting the battery help/ or cause any issues? Cheers |
I thought holding down the park brake while turning ignition off would stop it applying
Hi Andy. Not quite isolating but I’m just not driving the car at all. I know how temperamental these bad boys are so just wanting to be prudent till we can all get back enjoying them again. |
| Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1054
If its left outside, then just get a Solar Battery Charger - loads on eBay.
| knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1139
Inflate the tyres to prevent flatspotting. I've SORN my RRS and inflated the tyres to the maximum rating (50 psi) whilst it is stood idle. I've also connected my Ctek charger to keep the battery topped up. Kev
