Home > General > Auto high beam
Matt preece
United Kingdom 2013 Range Rover Sport SDV6 HSE Fuji White
Auto high beam
Hi my 2013 rrs auto high beam feature does not seem to work any ideas cheers
Post #597295 Fri Apr 03 2020 1:35pm
Puslinch
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Firenze Red
I have MY12, it works however I never use it. It's not quick to change dip/main. 2018 Telsa MS
2012 Range Rover Sport HSE+
1990 Porsche 944
1985 LR 90 Soft top V8
Post #597297 Fri Apr 03 2020 6:35pm
insiorc
Scotland 2013 Range Rover Sport SDV6 Autobiography Firenze Red
Re: Auto high beam
Puslinch wrote:
I have MY12, it works however I never use it. It's not quick to change dip/main.s
I agree with the above, I have it on but you have to anticipate whether it is likely to go to dip quick enough or not, it depends whether the approaching car is on a corner, in a dip or behind a bump etc. It is very quick at going back to full beam which is why I still use it, and as soon as you manually operate it then it stays manual until the stalk is pushed fully forward again.
For the OP's question, I can't remember but is the on/off option in the on screen menu accessed via the stalk? 13MY Range Rover Sport Autobiography SDV6 - mine
14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's
99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite
Post #597298 Fri Apr 03 2020 6:44pm
ilard
Yes, auto high beam is buried in the menu via the stalk.
The auto high beam will only come on if it's nice & dark and there are no light sources, e.g. no other cars (obviously!) and nothing reflective like road signs. It's quite cautious. It deactivates maybe 1 to 3 seconds slower than a human would, depending on road conditions. it's not especially happy on winding country roads when a car can approach all of a sudden (we see the lights a mile off illuminating hedgerows, but the car does not). L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
Post #597299 Fri Apr 03 2020 6:55pm
knwatkins
Has anyone got experience of this function in any other vehicles?
A while back, I mentioned to a mate of mine that the LR auto high beam wasn't the best, but he said his Mercedes system was really good. Kev
Post #597300 Fri Apr 03 2020 7:51pm
syl
I think it’s really good on both of mine. RRS MY17 SDV6 AB
Evoque MY17 TD4 AB
Post #597301 Fri Apr 03 2020 8:09pm
LandPhil
United Kingdom 2013 Range Rover Sport SDV6 HSE Ipanema Sand
I have an MY12, registered 2013, one of the last RRS1s. Don’t have HBA So not used to it, but your car is now 7 or 8 years old, the technology is stone aged.
My friend has a 2 year old Merc GLC with HBA and that is far too slow to react in most cases.
Post #597303 Fri Apr 03 2020 8:24pm
I found it to slow to dip and to easily activated by reflective road signs so switched it off. Setting is in the vehicle setup menu via r//h steering wheel menu button.
Post #597309 Fri Apr 03 2020 9:49pm
IanV8
Scotland
I find it works well but sometimes it confuses me, if I am following another car the blue high beam light stays on but the headlamps have adapted to the situation in that they don’t light up the car in front but still light up the nearside verge.
They also cope with driving on the other side of the road automatically.
Ian 2018 Indus Silver SDV6 Autobiography normally towing a Buccaneer Cruiser.
Post #597335 Sat Apr 04 2020 11:16am
ilard
You have Matrix LED but the OP has bi-xenon in an L320.
I have Pixel LED and mine will drive in full beam amongst traffic, eg an unlit motorway and it’s quite freaky to see the ‘dance’ of the adapting light beams. L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
Post #597341 Sat Apr 04 2020 12:39pm
Puslinch
My Tesla Model S is spot on with auto high beam, I couldn't react that fast! 2018 Telsa MS
1990 Porsche 944
Post #597353 Sat Apr 04 2020 4:18pm
Zilch
Australia 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
first thing i disabled on mine when i picked it up in 2010, it caused no end of grief due to
the slowness of response.. got blinded by a few Semi trucks who thought i was being deliberately
discourteous .. should be renamed Auto high beam annoyance.. Another Pommie Bar Steward down under
MY20 Defender 110 SE P400 Eiger/Ebony
MY10 3.0 RRS TDv6 Fuji/Ebony/Anigre
Post #597373 Sun Apr 05 2020 1:36am
Brit Plumber
I have used the same HBA in the USA without issue and was very impressed. The same system in the UK isn’t anywhere near as good. I can only put it down to straighter and wider roads with less cluttered verges in the US. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #597378 Sun Apr 05 2020 9:32am
