Home > Faults & Fixes > Front nearside sudden squeaking |
Macdaddy Member Since: 12 May 2012 Location: NW Posts: 101 |
Does it stop when you touch the brakes?
Wed Mar 11 2020 11:07pm |
Spangler Member Since: 02 Mar 2019 Location: Kent Posts: 98 |
It does but thats due to the wheels stopping, it happens when the wheels are rotating. Its bloody annoying! |
Thu Mar 12 2020 10:00am |
Thu Mar 12 2020 10:01am |
That’s identical to mine.
Thu Mar 12 2020 10:31am |
Thats a stone stuck between the Disk Guard and the brake disk itself. Try reversing as sometimes they will come out 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Thu Mar 12 2020 2:55pm |
I shall try that tomorrow Buckster and have a look around the guard. Thanks buddy |
Thu Mar 12 2020 9:18pm |
Yeah they are Brembos - I'll have a closer look over the weekend as well, up to my eyeballs renovating the whole ground floor of the house so havent had a chance yet. Let me know how you get on with the jetwash blast please |
Thu Mar 12 2020 9:21pm |
Just to update since a good blast paying attention to brake shields the squeaking hasn’t returned on mine. That said in this current situation we haven’t been doing the mileage we were doing.
Thu Apr 02 2020 11:29am |
Did the jetwash thing and noticed whilst doing it that the rear n/s brake shield looked very close to the disc so used a screwdriver and prized it away, jacked each corner up and liberally sprayed some lubricant around all the linkages and moving parts - the noise then went so happy days I thought until today.......popped to the shops and on the way back it was back again. I have hardly used it recently and it hasn't had a good clean since last time so it's back on the to do list once I find the time away from this renovation at home ( which has now gone from a new kitchen to redecorated, dining room, utility, hallway and stairs! ).
Thu Apr 02 2020 9:25pm |
I would check your hand brake shoe lining. Mine did this and would do it all the time except occasionally when braking but it was soon back. It then stopped as quick as it started and the started again 200 miles later. The brake lining was braking down and bits would get jammed until it wore away and then it would be fine....until the next chunk separated. I ended up replacing both discs (scored hand brake surface on the left), both sets of shoes and both sets of rear pads. 2012 5.0 SC AB
Fri Apr 03 2020 1:12am |
