Home > Technical > 2007 RRS TDV6 firing but won't start...HELP PLEASE |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4753 |
I would still check fuel is coming out the tyre valve at the rear top of the engine |
Fri Mar 27 2020 10:46am |
interjen Member Since: 27 Mar 2020 Location: Lincolnshire Posts: 3 |
Many thanks for your reply Andy, yes fuel is coming out, I've also tried the easy start in the inlet trick but that doesn't make any difference. I'm thinking Crankshaft position sensor at the moment??.. |
Fri Mar 27 2020 11:09am |
If you have an assistant remove the oil cap and see if the cam is turning over when cranked.
Fri Mar 27 2020 12:23pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4321 |
What was the ambient temperature this morning? |
Fri Mar 27 2020 12:40pm |
Thanks for the replies, it wasn't cold. |
Fri Mar 27 2020 1:43pm |
