![]() | Home > General > Xenon lights not working... bulbs replaced and still issues |
| flindersstation Member Since: 02 Jan 2019 Location: Scottish Highlands Posts: 17
Hi there
Good thinking! I swapped the units around and the power to both is good. Also cycled through all 3 bulbs and they are all good. Both igniters work. So by a process of elimination it’s pointing to a bad controller or whatever this box of tricks is.... unless some dodgy connections within the light unit. Thanks for your help so far ... I don’t really want to unscrew both of these boxes yet as I may end up with no lights if it goes wrong .... 2007 RRS 2.7 HSE (Current)
Here’s the part I think I need
I thought this might be some kind of controller but it's a headlight ballast... might be same thing |
Replaced a few of them lately. Easy enough to swap over for testing purposes |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5138
You can sometimes get half broken lights off eBay and take if the part you need |
Yes, only 3 screws to remove the ballasts. I swapped them round and got the other light working. So now I know I need a new ballast. I now know a lot more about Xenon lights than I did this morning, I thought it was just a simple bulb replacement. This is all easy when you know how! 2015 Audi A1 1.4TSI (Current) 2015 Audi A6 2.0 TDI (Gone) 1994 Pajero 2.8 TD (Gone) |
Thanks, I will have a look - one of my lenses is clear and one is yellow, so I could also do with getting some new lenses (if that's what you call them... the glass at the front 2015 Audi A1 1.4TSI (Current) 2015 Audi A6 2.0 TDI (Gone) 1994 Pajero 2.8 TD (Gone) |
You need to put the headlight in the oven briefly to remove the glue.
| Nigex4x4 Member Since: 17 Jul 2014 Location: scarborough Posts: 22
I watched a youtube vid on renovating headlamps and tried it myself, worked a treat! Might be irrelevant here but you never know. Hope it helps. Nige 2005 RRS HSE Arctic Frost (more like Scotch mist) "When you are going through Hell - keep going!" Sir W Churchill Free plumbing advice to fellow sufferers |
| knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1139
Did you seal the light afterwards Nige? If so, what did you use? Kev
Hi Kev, no I didn't mate. The vid I watched suggested an array of treatments but he favoured a clear film you can buy. He also used a clear acrylic lacquer. Hope that helps, think he was mexican or something, real pro.
