![]() | Home > General > Using headlight LEDS as DRL |
No, can only be done in conjunction with dipped headlights using the IID tool, although I believe others have done it via the fusebox by bridging the sidelight fuses somehow. Sure someone will post a link to how they manged to do it.
I’ve done mine so that as soon as the car unlocks, the front and rear LED sidelights come on. If the car isn’t accessed in about 5 minutes they then switch off so they’re not left to drain the battery. I just used 4 brake out fuses, 2 pairs wired to a 4 pole on/off switch (so I can turn them off it goes to a garage).
idi Member Since: 19 Nov 2019 Location: England Posts: 134 ![]() ![]() |
See this topic:
jason-nike Member Since: 08 Nov 2013 Location: sussex Posts: 207 ![]() ![]() |
Done exactly as Brit Plumber says, bridge the fuses and LEDs come on when you unlock the car and stay on, then go off when you lock the car.
As above, just bridge the connections in the fuse box.
