Home > General > Internal 'ticking' on turning
abiopete
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Firenze Red
Hi All,
Picked up my 1st ever RRS1 2013 3L Autobiography Saturday and so far loving it.
There is however a weird strange 'tick' coming from inside the vehicle when cornering or changing direction. It sounds a bit like a relay click from somewhere in the back or boot.
Is there some sort of tilt detection system which would make this noise? Its hardly loud or distracting but if there's an issue i'd rather know..
Thanks in advance.
Pete.
Post #595943 Tue Mar 03 2020 8:55am
mgrover
Sure its not the fridge relay going on and off?
Post #596941 Tue Mar 24 2020 4:29pm
The tilt detection is limited to two accelerometers (neither in the boot) and a yaw sensor (also not in the boot). 2012 SDV6 - it's missing a couple of cylinders
Post #596944 Tue Mar 24 2020 5:27pm
Seatown
Location: Moray - if you're a courier, yes it's mainland UK & no it's not in the Highlands
Perhaps it's the load cover? Mine isn't a tight fit in the side trim and does make a noise as it moves from side to side, especially when its been removed and refitted. 2010 TDV8 - current - my first RRS, loving it so far......
2005 Cayenne S - handling defied physics and what a sound, so sod the mpg!
1995 Disco TDI- surprisingly reliable, shame about the peeling dash & other trim
Lots of other non 4X4's in between times.........
Post #596956 Tue Mar 24 2020 6:33pm
knwatkins
Or the rear seat belt has moved down the side of seat? This has the habit to cause a rattle.
Also, are you sure it's inside the car and not a suspension component? Kev
Post #596964 Tue Mar 24 2020 7:54pm
abiopete
Never have it turned it on, it does sound like a relay actuating though..
Post #596988 Wed Mar 25 2020 12:15pm
abiopete
Good call actually, didn't notice the ticking on the test drive and it didn't have one fitted then so i had to go back and collect from the dealer.
I'll get rid of it for a couple of days.
Post #596989 Wed Mar 25 2020 12:17pm
abiopete
The seat belt i'll have a look at. Pretty sure its within the car so i'll try the other elimination suggestions first.
Thanks everyone.
Post #596990 Wed Mar 25 2020 12:18pm
