Home > Technical > Black Badges
Page 1 of 3 123>
Brian Mason
United Kingdom 2012 Range Rover Sport SDV6 HSE Sumatra Black
Black Badges
My HSE has the nicer black external badges, but the yukky green ones on the internal door cards and steering wheel. I know the black door badges are cheap and easily fitted but is there anyway of changing the steering wheel centre badge without buying a whole new airbag? Thanks! Rolling Eyes
Post #58984 Sat Sep 30 2006 2:59am
Bobby
Make a search. I remember seeing a post on this... . Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #58986 Sat Sep 30 2006 3:14am
Brian - you need to buy one of the wheel caps with the black badge. Remove the badge from the plastic carefully. As for the steering wheel the badge there is attached with 4 long prongs, you need to remove this using a screwdriver and a lot of courage but it will come out. Once out stick the new black badge in using double sided pads. There is a thread about this somewhere. 2005 Zambezi TDV6 - Gone but not forgotten
Post #58992 Sat Sep 30 2006 8:33am
Q8_LR3
Kuwait
You are looking for this..
http://www.rangerovers.net/forum/viewtopic.php?t=8544 05' LR3, V8 HSE, Adriatic Blue
Post #59405 Mon Oct 02 2006 10:19am
Brian Mason
Thanks fellas. It'll probably be easier to just buy the black/silver door badges as ther're very cheap (£2.50) and will save all the fuss. However, the steering wheel sounds a bit tricky and the sort of job that Im bound to screw-up (sli[p and damage the black plasic surround). But, I'll give it a go.
Thanks to all of you again, much appreciated!!! Fingers crossed?
Post #59683 Tue Oct 03 2006 12:19am
Roland
Switzerland
Brian, I will have exactly the same done by my dealer in a week or so.
Apparently it's a piece of cake and I only have to pay for the badges but not for their work. SOMETIMES YOU'RE THE BUG AND SOMETIMES YOU'RE THE WINDSHIELD
2010 TDV8 Ultimate Edition, zermatt-ebony-grand lacquer, and all the goodies, plus Superchips Bluefin ECU performance upgrade, Gibson Performance exhaust tips
gone after only 7 months: MY10 TDV63.0 HSE, zermatt-ebony-anigree, Dynamic Response, Rear diff-lock, flappy paddles, premium leather, Sunroof, PTI, privacy glass, S/C design 5 Spoke Diamond Turned alloys
Post #59773 Tue Oct 03 2006 3:58pm
Brian Mason
Hi Roland. Ive just ordered the parts: doors badges about £4 each, centre cap £8, plus VAT. I wish my dealer was as generous as Id happily bung £20 for supply and fit. Please let me know how it goes as Id welcome further fitting tips before I set out with my sledge-hammer!!! Regards and Thanks! Laughing
Post #59844 Tue Oct 03 2006 5:36pm
You can do all this work yourself! RRS TDV6 Gone but still around
Post #59845 Tue Oct 03 2006 5:39pm
Brian Mason
Yep, all sorted. A tip for the removing steering wheel badge is to carefully drill a small pilot hole through the centre, not penetrating the air bag cavity, then insert a self-tapping screw and pull out using pliers. Takes a few minutes and the new badge is ready to insert using araldite or sticky pads. Looks much better than the agricultural green. Thanks for the advice fellas! Smile
Post #61008 Sat Oct 07 2006 4:07pm
Cool Thumbs Up RRS TDV6 Gone but still around
Post #61010 Sat Oct 07 2006 4:59pm
Singletrack
Belgium 2006 Range Rover Sport TDV6 HSE Java Black
That sounds just a bit too scary for me Shocked Shocked I'm going to try and convince my dealer to do it. At least he can't refuse on the basis that this would threaten the "conformity" of the car. Wink
Wife takes the car in for it's 1,500 KM service next week - she'll ask them to order the door and steering wheels badges then. He's apparently been impatient to see the cosmetic mods I've made to the car. 2006 Range Rover Sport TDV6 HSE, Java/Ebony/Cherry, Privacy, Sunroof, PTI, Premium Sound, SatNav, Cold Climate, Tow kit, CarStyle coded grill and vents, Tasmods, Stormers, JE Exhaust, Autobiography badge
Post #61011 Sat Oct 07 2006 5:29pm
very good tip Brian! 2005 Zambezi TDV6 - Gone but not forgotten
Post #61012 Sat Oct 07 2006 5:39pm
RRUK
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Stornoway Grey
I agree that the green badges look pants, Landrover should make the black badges standard, and then come up with a DIFFERENT badge for the Supercharged. Perhaps brushed silver with black letters as an opposite?
(Then everybody would want whatever the SC had on it I guess!) L319 D4 HSE
1998 110 TUM HS FFR Hard Top XD WOLF
1982 Series 3 SWB
Post #61022 Sat Oct 07 2006 7:27pm
Unless they make the green ones the SC ones and the black ones the normal! Then we would all want the green ones again! Confused? Confused 2005 Zambezi TDV6 - Gone but not forgotten
Post #61023 Sat Oct 07 2006 7:34pm
Brian Mason
Good point. But the black and silver badges DO genuinely look much better and classier than green and gold. So, I honestly dont think its because theyre Supercharged badges, its entirely due the genuine asthetic superiority. Perhaps the black/silver should indeed be standard and reverse the colour combination to silver/black on the Supercharged? Then both would look in keeping with Range Rover prestige and status.
By the way, I used a Dremmel drill and it flew threw the steering wheel badge which is thin like tin. The four securing prongs at the back are bent inwards behind the plastic but give gradually under constant pressure. Just pull and itll come (said the actress to the bishop). I didnt want to prise the old badge off in case it damged the black plastic surround. The door trim badges are exactly the same size as the steering wheel so you dont need to prise one out of a wheel centre cap which is harder work and more expensive. Just but three door badges at about £3.50 each. Its honestly easier and quicker than I thought..., just go easy with the drill!!!
Post #61055 Sun Oct 08 2006 5:04am
Page 1 of 3 123>
