Home > General > Turbo and Preventative Maintainence
mikey7985
Wales 2009 Range Rover Sport TDV8 HST Stornoway Grey
Hi I’m back after several years of getting over my 2.7 HSE blowing it’s Turbos!!
I’ve bought a 3.6 TDV8 HST with 98k....... just wondering what I can do to help keep the turbos in good working order?
I’ve been looking at Terraclean but not sure about it.
Any other preventative maintenance tips would also be great.
Mike 2009 3.6 TDV8 HST
Post #596807 Sat Mar 21 2020 3:09pm
Dave-t
i'd start at your signature...….. Whistle Whistle Joined the X5 45e club
1994 Defender 90 300 tdi
Post #596808 Sat Mar 21 2020 3:29pm
Brit Plumber
I’ve heard that the main one is not to turn the engine off straightaway. Give it a little time at idle to let the Turbos spool down and cool down. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #596810 Sat Mar 21 2020 5:13pm
mikey7985
Lol Dave I did read that after posting and think the same!!
Nice one Brit I heard the same..... might get a turbo timer fitted because the Mrs just won’t listen!! 2009 3.6 TDV8 HST
Post #596814 Sat Mar 21 2020 5:52pm
Seatown
Location: Moray - if you're a courier, yes it's mainland UK & no it's not in the Highlands
A spell at tickover after a long/fast run always a good thing and I've always understood that frequent oil changes (say every 4/5K miles), especially if lots of short journeys. I've had mine a year now and that's been my routine so far. 2010 TDV8 - current - my first RRS, loving it so far......
2005 Cayenne S - handling defied physics and what a sound, so sod the mpg!
1995 Disco TDI- surprisingly reliable, shame about the peeling dash & other trim
Lots of other non 4X4's in between times.........
Post #596821 Sat Mar 21 2020 9:18pm
mikey7985
Nice one Seatown 👍👍 2009 3.6 TDV8 HST
Post #596823 Sat Mar 21 2020 10:06pm
knwatkins
^^^ this Kev
Post #596827 Sat Mar 21 2020 10:40pm
mikey7985
Roger that knwatkins 👍👍 2009 3.6 TDV8 HST
Post #596832 Sun Mar 22 2020 12:08am
Eaters
I've been using Redex for a coupe of years now. Tesco often have half price offers (£2 instead of £4) on the 2 shot bottles so I buy few when the offers are on. That works out at an extra £1 on the cost of your fill up. I have no idea if it helps or not but I'm guessing it can't hurt. Time will tell but I am on 95,000 miles now so heading rapidly towards the 100,000 mile mark. And yes, let the engine run for a bit before turning off. I think it says something to that effect in the handbook. Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #596852 Sun Mar 22 2020 11:11am
mikey7985
Thanks Eaters........ and thanks all.
I hope the previous owners of my HST were as on the ball with the shut down procedure otherwise I’d guess the damage is already done 🙈. Nevertheless I’ll stick to it strictly. 👍👍 2009 3.6 TDV8 HST
Post #596853 Sun Mar 22 2020 11:19am
Goffy
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Alaska White
It's my understanding that turbos' bearings are lubricated by circulating engine oil. If you switch off the engine before allowing the turbos to cool down for a couple of minutes or so, then the oilways carbonise and block up which stuffs the turbo.
Honest John keeps repating this advice to anyone who will take notice.
Post #596854 Sun Mar 22 2020 11:29am
mikey7985
Yeah that sounds about right to me Goffy........ I’m intending to stick to regular oil changes with the Castrol 5/30 A5 and always allow the engine to idle for a minute or so before shutting off. I’ll just keep my fingers crossed. Out of interest what’s the general consensus on what it would cost me to replace the turbos in the even of failure? 2009 3.6 TDV8 HST
Post #596903 Mon Mar 23 2020 8:52pm
Replacing the turbos on a TDV8 will be £5k if they both need doing, and assuming proper units are used. Buying "refurbed" units from ebay will be a false economy. 2012 SDV6 - it's missing a couple of cylinders
Post #596905 Mon Mar 23 2020 10:08pm
mikey7985
Jesus H Christ!!!!!!...... really RRS????? That’s crazy......... I kinda hope this apocalypse takes me before these turbos need replacing in that case!! Is it a main dealer only job in your recommendation? 2009 3.6 TDV8 HST
Post #596907 Mon Mar 23 2020 10:24pm
knwatkins
Nothing is ever a recommended main dealer job in the Land Rover world. Get yourself a good independent. Kev
Post #596908 Mon Mar 23 2020 10:36pm
