Home > General (L494) > Timed climate / remote control
crasher73
Hi all,
Does anyone know if there has to be a minimum / max temp for the timed climate to work properly? I've not tried it with the remote so thought I would randomly give it a go however a slow flashing red light on the fob indicates an error (although I can't find a definitive answer on what the error might be).
I've used it before by setting it from within the car but never the remote.
Any guidance much appreciated.
Post #596770 Fri Mar 20 2020 3:46pm
scrumps
Flashing red means the car hasn’t received and actioned your “on” commend.
Try getting closer, or re-pair the remote.
I usually leave mine set to 22deg and “auto” on the climate.
No problems.
Have you tried using the remote App, it starts the engine, but at least it’s better than a cold car.
Scrumps Somerset - Where the apples do grow and the cider do flow!
2021 Defender 90 D250 HSE in Tasman with white roof.
24MY D300 AB - Verasine Blue - 😀
19MY SDV6 AB - Byron Blue - Gone
17MY D5 SDV6 HSE - Firenze Red - Gone
16MY SDV6 AB -Aruba Silver - Gone
13.5MY SDV6 "HSE Black" - Baltic Blue - Gone
10MY TDV8 HSE Galway Green - Gone
14MY D4 HSE in Scotia Grey - Gone
05 TD5 D90 CSW in Cairns Blue
Post #596774 Fri Mar 20 2020 6:16pm
crasher73
Thanks for the reply. Any idea how you re-pair the fob, might be worth a try?
I need to get a dealer to reset I think as the previous owner has already set a pin code so the remote app is not currently an option - cheers
Post #596789 Fri Mar 20 2020 10:47pm
scrumps
1. The previous owner or the dealer should have removed the vehicle from their account so you should have a blank canvas.
2. To pair a fob, you pull one of the fuses for the FBH, wait a few seconds, put it back in and press the remote button within 10 secs and it should pair. You can find better details by searching the ‘net.
3. I just found this - it’s on aFF site but says it’s for a L494:-
http://www.fullfatrr.com/gallery/albums/us...re~861.PNG
Post #596804 Sat Mar 21 2020 10:50am
