Home > Faults & Fixes > Weird Accelerator
willster174
United Kingdom 2011 Range Rover Sport 3.0 TDV6 Autobiography Siberian Silver
Weird Accelerator
Hi All
I am new to RRS ownership after picking up a 2011 Autobiography Sport on Saturday.
I love the car but it has a strange issue in that sometimes when i press the accelerator pedal lightly nothing happens and I have to release and press again and then it seems to accelerate.
I hope that makes sense. It is almost as if it sticks or something. It can be a bit unnerving when pulling away if it happens
Has anyone else had this and if so can you point me in the direction of what might be wrong?
Thanks
Post #596447 Fri Mar 13 2020 3:36pm
It's a well known issue, sadly. It annoys the hell out of me at times.
Oh, and welcome to the RRS club. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #596457 Fri Mar 13 2020 6:05pm
Stevepd
I read on the Disco3 forum that putting it in Sand mode makes for a sharp getaway from junctions/roundabouts when needed.
https://www.disco3.co.uk/forum/delay-power...=Sand+mode 2006 2.7 TDV6 HSE in Cairns Blue.
Post #596460 Fri Mar 13 2020 9:52pm
Just sticking it in 1st gear will do the job most of the time. 2012 SDV6 - it's missing a couple of cylinders
Post #596462 Fri Mar 13 2020 10:05pm
willster174
So does that mean there is no fix for it?
it seems to be getting worse too as it did it about 10 times this morning
Post #596474 Sat Mar 14 2020 12:34pm
Puslinch
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Firenze Red
Two fixes I have a MY12, Sport mode or Alive Tuning. 2018 Telsa MS
2012 Range Rover Sport HSE+
1990 Porsche 944
1985 LR 90 Soft top V8
Post #596489 Sat Mar 14 2020 7:52pm
willster174
This problem is intermittant at all times not just when pulling away.
Sometimes I am driving in traffic and it speeds up and i push down and nothing happens so i have to lift off and then push down again for it respond.
It seems to be doing it more and more
On Saturday I pulled out to pass some cyclists and about half way when accelerating it just stopped going and i had to lift foot off and push it back down. I went back to the dealer but they said they didnt know what was causing it so I am going to take it back for them to test it for a couple of days
It also has a noisy compressor which is apparently the rubber housing which has perished meaning it is vibrating against the chassis
He said you can get a kit for this but havent been able to find one
Post #596566 Mon Mar 16 2020 11:29am
willster174
Post #596567 Mon Mar 16 2020 11:29am
As you proably have a AMK Compressor fitted it is quite likley the mounting bushes are worn, and this kit is the sort of thing you need. L/R used to do a kit LR061888 however that number is no longer any use as it now relates to the complete compressor.
https://www.ebay.com/itm/Land-Rover-Range-...3667008780
https://www.driveriteair.com/catalog/product/DR.12.011214-347/
Post #596571 Mon Mar 16 2020 12:31pm
willster174
Hi Col
Thats great thankyou very much for your help with this
Post #596576 Mon Mar 16 2020 12:58pm
I think you need to confirm it is a Amk compressor and not Hitachi first, easy enough just drop plastic cover and look at how it's mounted to chassis as both totally different. Not sure when they started fitting the Amk, but I think it was from Vin. BA708255 on, although they did revert back to the Hitachi for a short time during MY12/13 production.
Amk looks like this underneath.
Hitachi mounting bracket looks like this, rubber mounts are RVL500014
Post #596608 Mon Mar 16 2020 10:34pm
Might be worth getting the throttle pedal potentiometer checked in some way if possible, only a suggestion. Do you have any fault codes like PO123-00 or similar?
Post #596613 Mon Mar 16 2020 11:52pm
Themoog
Or 05 supercharged does that with the accelerator sometimes. If I've just switched it on and after a few minutes I blip the throttle, nothing happens. Second time it's OK. Its almost like the engine is catching up with the pedal if the see what I mean.
Post #596703 Thu Mar 19 2020 7:24am
