![]() | Home > Technical > Oil Leak |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4521 ![]() ![]() ![]() |
It's very easy to snag the seal on the drivers manifold when refitting
Darren Anthony Member Since: 08 Mar 2019 Location: Birmingham Posts: 30 ![]() ![]() ![]() |
Definitely hoping it's not that.
As I actually had a bit of time while there was some daylight, I had a look around as best I could in the engine bay. Doesn't seem to be any oil anywhere near the top and cant see any looking down all the possible gaps with a bright torch, so it must be coming from somewhere a bit lower down that can't be seen from above.
Another thing I just thought of that I hadn’t mentioned. It only leaks with the engine running. Don’t know if that narrows anything down? 2010 RRS 3.0 TDV6 HSE
Robs_2007_sport_hse Member Since: 12 Mar 2020 Location: Devon Posts: 5 ![]() ![]() ![]() |
I just done a oil leak on mine. it was the oil pump seal to the block and front crank shaft oil seal both humping out oil and throwing it every where...
As much as I was hoping it’s not going to be the inlet manifold, it just seems too much of a coincidence for it not to be. Started leaking almost straight after having it replaced. Was completely fine before that.
Slight update.
Looks like you were right! Took it over to 4 W Motors on Tuesday and he spotted it straight away. So he's got it back in today and is fitting a new manifold gasket for me. 2010 RRS 3.0 TDV6 HSE 1992 Mazda RX7 FD3S |
