![]() | Home > Technical > Another slow battery drain |
squizzel Member Since: 13 Jun 2013 Location: wednesbury Posts: 193 ![]() ![]() ![]() |
I left my car at my moms house as i have had an operation on my shoulder. After 4 weeks the battery was flat and wouldn't start the car. The battery is 9 months old with a 5 year warranty. Anyway i left it untill i was allowed to drive again, so it had now been sitting for 6 weeks. Got the AA to come and jump start it, and got it home. Charged the battery the next day, but 2 days later when i started it up, i had the special programs unavailable message. I get this if the battery is low, so i checked and it was at 11.7v. It has happened a couple of mornings now, so i got a clamp meter and followed this. https://www.disco3.co.uk/forum/robbies-gui...19574.html
It's a YUASA battery with 5 year warranty from halfords. The only time it has gone flat is when it was left at moms for the 6 weeks. I will try and get a test done on the battery, i don't want halfords to test it first i want it done by an independant. Can i ask why to not do a drop test. |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5118 ![]() ![]() ![]() |
Sounds fine to me.
Passenger emergency lock had seized, took me 1/2 hour to get into the car.
insiorc Member Since: 17 Jul 2016 Location: Scotland Posts: 533 ![]() ![]() ![]() |
Hopefully if the battery is at fault then you'll get it replaced easily. The thing is with sitting 6 weeks and needing it jump started, how flat was the battery and for how long (I understand it unlikely you tested it)? For a standard lead acid battery we talk about the 'point of no recovery' being 0.8V per cell, so dropping below 9.6V will cause considerable damage especially if not charged for some time. Of course a charge can usually get it running again for some time but the damage will have been done. Why no drop test, really just because there are better ways nowadays with the fancy testers which can tell you so much more about the internal condition. A drop test requires the operator to know what he's doing, it can damage the battery slightly especially if done at an incorrect load. I've seen the sides of a battery blow during a drop test, luckily the bloke had full face shield, apron, boots, gauntlets etc. so got off with it - I must say that I started paying more attention to my own safety when doing battery maintenace after that, I wasn't so bothered with all the PPE (large battery bank UPS system maintenance). 13MY Range Rover Sport Autobiography SDV6 - mine 14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's 99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite |
A battery charger
battery was completely flat, couldn't unlock it. When i did there was nothing, completely dead. I have a 120A car starter and that wouldn't start it. The AA put a 400A booster on and it just turned it over enough to start it. But up to me parking it up there were no problems, but it discharged in 4 weeks, to the point it wouldn't turn over.
Take the battery back to Halfords. I bought one 12 months ago from Halfords and within 3 months it was goosed. Seams YUASA had a bad bunch, HSB090 I think mine was. I did post on the forum about it, I’ll do a search. 2019 5.0 SC SVA (Current)
Couldn’t find my post but the battery for my car was the 019 but I fitted the better 020. Quite a few owners have reported problems with these, mainly bad cells. 2019 5.0 SC SVA (Current)
I had two YUASA batteries fail in quick succession so scrapped them and fitted a VARTA AGM G14 (019) instead and never had a problem since.
Mine is an 019. Went back to halfords yesterday and had it tested. They said all it's coming up with that it needs a good charge. I had it on charge for 12 hours 4 days before, and as soon as we had a frost it was low again. As their tester just says it needs charging they won't replace it. |
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 932 ![]() ![]() |
If you are not using the car much, buy a CTEK battery conditioner (they don't like calling them chargers). You can leave it connected for ever as it continually maintains the battery level. My F type has been on CTEK since October as it isn't used during the winter & won't be used till April. Always starts first time (well it has up till now |
That’s how my battery started to fail and eventually after charging it all the time, it popped a few cells and gave up. After 48 hours on a CTEK it only had I think they said 7% charge. 2019 5.0 SC SVA (Current) 2012 5.0 SC AB. Sadly written off by a campervan 23 plate Focus ST (Current) 1942 VEP Ford GPW Jeep (Willys) (Current) 1943 Whites M16 Halftrack (Current) 16 plate Eurofighter Typhoon, 2 x Eurojet engines with 20,000lbs thrust each. 1380mph |
