Home > General > Deployable side steps Roof access mode.
Smarttech
My car has the genuine deployable side steps fitted but I'm having issues with them.
They work fine every time you open and close the doors.
The issue is roof access mode when you want to wash the car. Most of the time when you go in to the menu this option is greyed out so you can't get the steps to stay out. Leave the car for 10 ish minutes and it works fine but not much use if you can't use them when you need to.
Anyone else had this issue ? Or am I doing something wrong ? 2017 SVR. SVO Scafell grey Ebony interior
2012 3.0 SDV6 Autobiography santorini black with ebony/cirrus interior. Gone
Post #595975 Tue Mar 03 2020 10:10pm
Certainly won't pretend to know, but is there a setting in the menu some where you can set the time delay by any chance. Same as you can with various other functions. Only a thought.
Col.
Post #595977 Tue Mar 03 2020 10:32pm
scrumps
I’ve just worked this out on my 19MY AB with deployables.
To allow roof access mode whilst in the car, with the ignition on, put it in “Park’ and then unlock the doors with the switch on the drivers door. That enables “Roof Access Mode” to be selected through the ICTP screen.
Scrumps. Somerset - Where the apples do grow and the cider do flow!
2021 Defender 90 D250 HSE in Tasman with white roof.
24MY D300 AB - Verasine Blue - 😀
19MY SDV6 AB - Byron Blue - Gone
17MY D5 SDV6 HSE - Firenze Red - Gone
16MY SDV6 AB -Aruba Silver - Gone
13.5MY SDV6 "HSE Black" - Baltic Blue - Gone
10MY TDV8 HSE Galway Green - Gone
14MY D4 HSE in Scotia Grey - Gone
05 TD5 D90 CSW in Cairns Blue
Post #595978 Tue Mar 03 2020 10:41pm
Smarttech
Thank you will try this tomorrow. I managed to get it to work earlier but car has not moved for a day. Both times I have not been able to get it to work is after the car has been driven ! 2017 SVR. SVO Scafell grey Ebony interior
Post #595982 Tue Mar 03 2020 11:57pm
