![]() | Home > Technical > PHEV Home Smartcharger |
jra1234 Member Since: 06 Apr 2014 Location: Windsor Posts: 15 ![]() ![]() |
I have a 7kW installed (I don't have) 3 phase so this is my realistic limit, P400e charges in c. 2.5h on this. I had a tethered Rolec (non smart) installed. I had mine installed before the need for it to be smart came in to get the grant, this is what I wanted. I use the timing features in the car to charge overnight. You have to use the car settings to pre-heat I think. I switched my electricity provider for low cost overnight rate (5p).
jimbg Member Since: 29 Jan 2013 Location: No longer by the River Dart.... Posts: 1905 ![]() ![]() |
5p is a good rate, can I ask who that is with and what is the normal day time rate? 2023 P440e SE Dynamic on order -cancelled
Octopus Go Tariff which is targeted at electric car owners. 00:30-4:30am 5p per kWh, other times 13.8p/kWh, daily charge 25p. Needs a smart meter, they will install (a newer model). https://octopus.energy/go/rates/
Great, I looked at EDF but stumbled at the Smart meter requirement. 2023 P440e SE Dynamic on order -cancelled
Rusty Ranger Member Since: 03 Jan 2020 Location: East Sussex Posts: 61 ![]() ![]() |
Thank you for your comments. That is helpful. I think that a 7kW charger would be fine for me. I will definitely go tethered. I shall look at the Rolec. Choosing a colour would be good too. Quite a lot of the chargers look like... well, electric chargers. The Andersen charger is designed to look a bit like a mail box, which my wife thinks is aesthetically better. |
The EO is probably the smallest and neatest:- https://www.eocharging.com/eo-mini-pro?gcl...EiEALw_wcB 2023 P440e SE Dynamic on order -cancelled
Good call, Jimbg! It is very discrete, and has some good colour options too. |
Yes, my wife had a lot to say in the decision! |
