Home > In Car Electronics > After Market reverse camera Help
JoeMoore
Ireland
Hi , if installed this reverse cam ( Auto Vox c2 ) but I’m not sure which wire to connect to on reverse bulb connection ( Range Rover Sport 2008 ) .
If someone could point out the live at bulb and the ground in that would be a great help .
Regards
Joe .
[/url]
Post #595416 Sun Feb 23 2020 2:11am
JoeMoore
Ireland
What colour is live ?
What colour is ground ?
Theres 1 green and two black wires on reverse bulb , dont know what's what:)
Thanks in advanced.
Post #595417 Sun Feb 23 2020 2:15am
Reverse, Green wire with Brown Tracer Pin No.2 on main harness side of connector plug, Earth, Black wire Pin No.5. Not sure what the actual single colour's are on the lamp unit itself is, but If you connect it to the main harness side you will not have to disturb it if you need to remove the rear lamp for any reason or that's what I did at least on a previous sport.
Post #595418 Sun Feb 23 2020 3:16am
Well it’s not the black.
EDIT: as that is the earth you require
Post #595424 Sun Feb 23 2020 9:44am
What's not the black? really helpful so which colour is it on the lamp? the one which corresponds with pin no. 2 on the plug or goes to the reverse light bulb I imagine, at a guess I would say the green one
Post #595425 Sun Feb 23 2020 9:48am
I was being helpful.
OP put this one up, (black or green)
JoeMoore wrote:
Black is earth, so its not that.
Providing owner has the correct bulb holder, then yes, green.
As said, personally I wouldn't connect there. But for DIY I can see its easy.
I would connect behind the rear left panel inside the car (away from water).
or piggy back into a fuse behind the glovebox if I wanted a conenction at the front
Post #595431 Sun Feb 23 2020 10:47am
Yeah, sorry was a bit sharp, I was thinking more in response to part of my initial reply as opposed to the op original question, never really read that fully . Been a long day.
Post #595437 Sun Feb 23 2020 11:17am
JoeMoore
Ireland
Thank you , that all worked out fine .
Post #595451 Sun Feb 23 2020 5:02pm
That Looks quite a neat looking camera install. Thumbs Up did you remove the original nav. screen or is the car a SE?
Post #595457 Sun Feb 23 2020 6:05pm
Looks a basic car.
I would have thought the head unit had a camera input
Post #595464 Sun Feb 23 2020 7:36pm
JoeMoore
Ireland
Thanks ,yes SE model, I could have got the Original one but the quality of this after market Digital picture is superb and also a lot less hassle to install with a little help from here Smile
Post #595487 Mon Feb 24 2020 3:06am
JoeMoore
Ireland
Andy K wrote:
Looks a basic car.
Yes the head unit has a cam input but I needed to fill that open space , — and it’s a longer movement of the eyes way down there lol 😂
Post #595488 Mon Feb 24 2020 3:10am
