Home > Faults & Fixes > Hdc system fault and new starter motor
Rennywuk
I had a new starter motor fitted by my local mechanic following a dead RRS 2005 SC. Ever since I’ve been getting the hdc system fault and/or the ebrake error. It only lights up on starting the car and clears within a few seconds.
My question is do I need to replace the battery or brake switch?
At the point the car died the RAC tested the battery and the results are above.
Any guidance would be appreciated.
Post #594141 Sat Feb 01 2020 4:21pm
geoffsnook
When was it last replaced(Battery) if you dont know then change it as these don't like low voltage Thumbs Up
Post #594150 Sat Feb 01 2020 7:50pm
Devon Z
England 2005 Range Rover Sport TDV6 HSE Java Black
I had similar HDC errors when I purchased mine, engine always span over well and stated but kept getting warning lights whilst cranking. Checked the battery voltage while cranking and it was about 9volts, new battery and all is good, still only 10.5volts but no errors and engine spins faster.
Steve Steve
2005 2.7 TDV6 HSE, ongoing project.
1998 Volvo V70 R auto FWD, Back on the road again.
1999 BMW Z3 (owned from new) garage queen.
Post #595093 Mon Feb 17 2020 9:37pm
10.5V ? Sounds like the alternator is dead. 2012 SDV6 - it's missing a couple of cylinders
Post #595096 Mon Feb 17 2020 11:06pm
aaronjb
10.5V at rest, yes.. 10.5V during cranking, however, seems to be fairly normal - with a brand new battery and brand new Denso alternator (which isn't doing anything during cranking, really). Prior to battery change I also had 9V during cranking and the odd christmas-tree moment Smile
Pretty much all cars will drop well sub 12V during cranking due to the load of the starter - that's why, in days gone by, the ignition coil ballast resistor (which usually drops coil voltage to ~9V) would be taken out of circuit during cranking 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #595168 Wed Feb 19 2020 10:32am
Sorry, missed the "cranking" bit in the previous post. Embarassed 2012 SDV6 - it's missing a couple of cylinders
Post #595170 Wed Feb 19 2020 11:26am
aaronjb
Ah, that'd explain it Mr. Green
Off to specsavers with you! Wink 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #595181 Wed Feb 19 2020 12:37pm
