Home > General > Tip if you have a puncture L494
Lindab
After struggling to remove the spare wheel with that Censored strap thing when wiring in my fag lighter charge socket in the boot, I realised that having a puncture anywhere apart from home would be a nightmare. The struggle to remove/replace the spare is a nightmare (suggest you try it) unless you phone the AA etc. So I bought a compressor/sealant kit (Ebay or Amazon is your friend. They are all the same so a generic one or one for another car will be fine unless you have a big hole, then its struggle with the wheel time.
Why didn't they keep to the previous method of winding down the spare wheel. Obviously cost, but they could have had a proper design study done instead of giving it to the tea lady (oops sexist) tea person to design.
Post #594998 Sun Feb 16 2020 1:47pm
riverblanche
agree they are Heavy Sad
but
I would rather have a full size spare, gives you chance to go where You want for the repair if possible,
if you fill it with the Gloop "most" tyre places will not clean the gloop out to fix a puncture its a new tyre each time Shocked
so a £25 repair has just cost £200
yes you can take your old tyre home, clean it yourself, then get it repaired and you have a spare in the garage.
like everything in life compromise/risk/chance its a balancing act Laughing
ps. I also carry sticky strings as well Rolling Eyes
Thumbs Up Porsche Cayenne 2022
gone Porsche Cayenne 2020
gone Corris Grey HSE Dynamic 2016
gone Ipanema HSE lux 2010
gone Rimini HSE 2005
Post #595017 Sun Feb 16 2020 7:21pm
Lindab
Sticky string ????????????????????????????
Post #595029 Sun Feb 16 2020 10:44pm
IanV8
Scotland
No choice for me, no space for a spare wheel. So it will be Mayday.
Ian 2018 Indus Silver SDV6 Autobiography normally towing a Buccaneer Cruiser.
Post #595045 Mon Feb 17 2020 8:41am
fkarim
Re: Tip if you have a puncture L494
I know ... they are heavy. I had a full size 21" spare in there and had to take it out a few times. Not to replace a punctured tyre/wheel but for other reasons. I didn't even have the helper strap thing as it was missing in the beginning and I got it from the dealer later Rolling Eyes so it was all by hand.
To answer this:
The previous way of storing the spare under the boot in RRS1 and Disco 3/4 left them prone to theft. It was too easy. At that time we used to complain about that design and wondered why didn't they make space for the spare inside the boot like FFRR. This very forum will reveal a lot of frustration if you search for "spare wheel stolen" or something along those lines.
I have no reason to defend LR and don't even own one of their products now but just offering some background. Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top
Gone: MY16 RRS2 3.0 SDV6 Autobiography Dynamic, Carpathian Grey & Santorini Black Sliding Pano/Ebony & Ivory 2 Tone
Gone: MY13 RRS 3.0 SDV6 HSE Black Edition, Orkney Grey/Ivory
Gone: MY09 RRS 2.7 TDV6 HSE, Santorini Black/Almond
Post #595052 Mon Feb 17 2020 9:33am
Tim in Scotland
The inside spare wheel well also allowed LR to design in a clean dry location inside the boot for the suspension compressor that in the previous generation cars was outside under the car 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #595059 Mon Feb 17 2020 10:20am
garrycol
Australia
 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #595060 Mon Feb 17 2020 10:32am
The underslung wheel was a rubbish design because it was easily stolen, it was also a pain to get out from under the back, unhook the cable, drag it the rest of the way out. Then you have to hook the removed wheel back on and winch it back up whilst easing it back in to place under the back end. Tension required on the cable at all times or it would go wrong and leave you unable to winch in. You get dirty every time. Pig of a job. 2012 SDV6 - it's missing a couple of cylinders
Post #595062 Mon Feb 17 2020 11:38am
garrycol
Australia
And you have to do most of that just to check the tyre pressure.
I had a flat last week and got the spare out and it was down to 16 psi - ok to drive on to go and get more air but if I hadn't got the flat this time, next time the spare may have been flat.
Noted for service time - drop the spare and top up with air.
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #595066 Mon Feb 17 2020 12:30pm
That's why I carry a tyre compressor in the RRS under the back seat (along with jump leads, tow rope, strop, fire extinguisher and a few other odds and ends). At least then, if the worst happens and the spare is low I can pump it up before driving away. Also useful if there is a slow puncture - had that before where the tyre looked low, checked and it was down and I saw the screw in the tread. Inflated to suitable pressure and then gentle mile drive to get it fixed. 2012 SDV6 - it's missing a couple of cylinders
Post #595071 Mon Feb 17 2020 2:17pm
garrycol
Australia
Yes having a compressor is a good idea - when I had my flat I was going to just put the strings in but without a means of pumping up there was no point - noting the strings are for emergency use only and you will have to get the tyre repaired properly anyway but I would prefer to do that at my leisure rather than as an urgent action.
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #595105 Tue Feb 18 2020 2:42am
Always carry this in the boot just in case.
Post #595106 Tue Feb 18 2020 3:40am
PIG88
We had our external spare wheel stolen twice on our 2012 RRS (they even took the ‘anti theft’ plate on the second occasion). I wouldn’t want to go back to the external arrangement - but then I’ve never yet had to remove the full size wheel from the internal well on the current one. Carrying a sealant kit for emergencies sounds like a sensible plan. Current: 2020 P400e HSE Dynamic
Gone: 2016 SDV6 HSE
2012 SDV6 SE
Post #595501 Mon Feb 24 2020 12:00pm
