Home > Maintenance & Modifications > Turbo lag/ lack of torque since remap potentially before too
Naeemm
Hi guys.
Have a RRS 3.0 tdv6 2010. Read a few posts on the flat spots and turbo lack when accelerating at junctions and that shunt when re-accelerating so I booked my car in for a remap at Alive.
All went well with Stewart there and also on test drive noticed the smoothness in power delivery and also pretty much non existent lag..
Its been a 10 days since having it done and the cars just been driven locally and for some reason it's developed a lag again. So when I'm driving in the Lowe gears around 20-30 if I put my foot down there's a delay and a slight vibration I can feel before the car then picks up and accelerates.
Spoke to Stewart and he's invited me back to Lincoln to do rolling Road but it's about 1hr45min drive. He did say it's probably not related to or caused by the map and may be a turbine shut off valve sticking issue but just a possible diagnosis not definate until its been checked.
Has anyone experienced this in general or after a remap and what could it potentially be? Will try and get it booked in locally but just wanted to see if anyone has experienced this.
Any advice or help would be welcome
Thanks
Post #595024 Sun Feb 16 2020 10:19pm
Disco_Mikey
Brake switch and PCM update, known issue. JLR released a bulletin about it
However, the update will overwrite your remap. Check with Alive that they can reapply the map afterwards
Post #595025 Sun Feb 16 2020 10:25pm
Naeemm
Many thanks for that. So do I just need to book it in with JLR...?
Hopefully it is that.
Is there a site which mentions the bulletin?
I'm sure alive can upload the file for a small cost from what I remember.
Thanks again Wink
Post #595028 Sun Feb 16 2020 11:25pm
Naeemm
So called JLR customer care and they checked and no pcm recall or update showing for my RRS.
I'll be booking it in with a local specialist but anyone on here with an idea about what it could be? Confused
TIA.
Post #595313 Fri Feb 21 2020 2:49pm
HughN
Wales
Could it be a loose intercooler hose (that has popped off with the more lively boost)?
Post #595377 Sat Feb 22 2020 3:57pm
