![]() | Home > Maintenance & Modifications > boot switch replacement |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5152 ![]() ![]() ![]() |
If you are referring to the one between the rear number plate lights it is simply plug and play nothing needs coding. You will need to remove the inner tailgate trim panel to access it though. I did mange to get a new genuine L/R one of ebay although not expensive from L/R, if I remember right the are actualy the same as a Freelander but the ewok is different, sure have a spare one here could get part number off box if any help.
Rusty Novice Member Since: 04 May 2018 Location: Staffordshire Posts: 34 ![]() ![]() ![]() |
hi buddy
Number on the box is LR042648 but I think it has now changed to LR083610
