![]() | Home > Wheels & Tyres > Steel Wheels |
I would have thought it would be the same as the alloy wheels Hugh (140Nm). Kev
120-130nm Andy.
HughN Member Since: 10 Sep 2017 Location: Near Llanybydder Posts: 651 ![]() ![]() |
Rusty Ranger Member Since: 03 Jan 2020 Location: East Sussex Posts: 61 ![]() ![]() |
Do you need to use shorter wheel studs? The holes in steel wheels will not be so deep as alloys. |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 783 ![]() ![]() ![]() |
What steel wheels have you found that's rated to the weight of the RRS? I wasn't aware that steels were ever fitted to them, other than the totally useless space-saver. I seem to remember steel wheels being fitted to the base D2 but they were quite skinny and 16" or 17" which wouldn't go over your brake disks. |
Nuts on RRS not studs ![]() 21 Ford Ranger Gone but not forgotten Focus RS Red Edition 2015 RRS AB Fuji. 2014 RRS SC Santorini 2016 VW Amarok 2014 RRS AB Fuji 2012 RRS Red Edition Fuji 2015 Nissan Navara 2012 RRS SE Santorini 2008 RRS White 2007 RRS Santorino |
These: https://www.tuffantuk.com/wheels |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1070 ![]() ![]() |
17" wheels will go on a RRS TDV6 (2.7). Either D3 17" if you can find them or BMW X5 rims with different wheel nuts.D2 rims have the wrong offset/centre hub hole for the D3/RRS. 07MY RRS TDV6 Arctic Frost Aspen Interior |
Well you certainly won't have to worry about kerbing your rims with those on. I guess that if they'r rated for a D4 they should be OK on your RRS. |
Duc750 Member Since: 27 Mar 2019 Location: Northampton Posts: 158 ![]() ![]() |
ARe these not the same as the Terrafirma ones that have been around for a while ? 2012 SDV6 HSE (technically its hers)
