![]() | Home > General (L494) > Gearbox Clunking & Air Suspension Noise |
Bardley Member Since: 26 Jul 2018 Location: Herts Posts: 150 ![]() ![]() |
This is likely to be drivetrain play. Have a look at all UJ's and visible areas first.
DangerMouseUK Member Since: 16 Jul 2016 Location: London Posts: 528 ![]() ![]() ![]() |
The gearbox (and car) have only done about 900 miles - is this normal?
Red Arrow Member Since: 06 Jun 2017 Location: Scotland Posts: 594 ![]() ![]() |
Are you lowering it prior to putting the handbrake on or after ? |
No letting it lower in situ.
splosh Member Since: 01 May 2019 Location: hampshire Posts: 11 ![]() ![]() ![]() |
I have had Range Rover's since 1972 so I can safely say I have driven a few and experienced their functions.
Cool I guess I'll turn off the auto EPB - why did they make it a feature if it knackers the car?
New SVR does the same thing too.
Noticed the gearbox only makes a thunking change, when you change into gear whilst the car is still over-revving to warm up.
Ash3 Member Since: 31 Aug 2019 Location: London Posts: 279 ![]() ![]() |
Thanks for the info DM...thought it was judt my car.
I thought it was just mine too.
Strange thing is this MY20 SDV8 clunks when changing from P to D after you’ve just started the car and the engine doesn’t even have a high-idle setting from the looks of things - minute you start it it just sits at a constant RPM that doesn't go down at all, probably older engine design.
RRS4ED Member Since: 05 Feb 2021 Location: Yorkshire Posts: 45 ![]() ![]() |
Don't have an RRS currently but having used the same ZF gearbox on my other cars i observed the same thing. BMW updated gearbox etc didn't work but if i followed following mine never made that clunk you described.
Cheers will try that.
Vaincarp Member Since: 26 May 2021 Location: Antwerp Posts: 1 ![]() ![]() |
Just wanted to share my experience.
