![]() | Home > Technical > Instrument Cluster |
you would need to have it reprogrammed to your car and save all the info from your previous panel there are people on here who have had them repaired on here try searching |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5090 ![]() ![]() ![]() |
I think it contains the immobiliser code
Gerd1986 Member Since: 07 Oct 2015 Location: London Posts: 303 ![]() ![]() ![]() |
James1974 on the disco3 forum can do it for you or there is a wealth of knowledge on there to do it yourself. |
rob cupples Member Since: 27 Jun 2018 Location: Stirling Posts: 30 ![]() ![]() ![]() |
I had similar symptoms on mine. I sent it away to instrument cluster uk and they repaired it successfully. no reprogramming required this way |
Timo Member Since: 15 May 2016 Location: Lancashire Posts: 36 ![]() ![]() |
Thanks everyone. I’ll pop over to the disco forum and try speak to james1974 |
aaronjb Member Since: 26 Jun 2019 Location: Northampton Posts: 447 ![]() ![]() |
Was an early symptom of this bits of illumination flickering? I ask because my 'mph' word flickers from time to time.. and planned repairs are better than 'oh balls none of the clocks work anymore' repairs! |
It had a slight flicker off then on. Then it would switch off all together for a long period |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 954 ![]() ![]() ![]() |
rev counter needle illumination on mine has flickered for a good while now,,, apparently its a common fault 2010 RRS, TDV8
