![]() | Home > General > What to buy? |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5145
yeah get the 4.2 SC if you can afford 13 MPG |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159
A £6k RRS is going to be pretty tired, to be honest. Take your time and find one with a huge pile of receipts that show things like suspension bushes having been done, gearbox flushed etc. And be prepared for bills as things will doubtless need doing to it. 2012 SDV6 - it's missing a couple of cylinders
| Amgmatt Member Since: 10 Feb 2020 Location: London Posts: 14
Thanks for taking the time to reply. What are the costly repairs for a rrs? Have heard about air suspension etc. But i assume consumables like brakes and tyres are expensive anyway! |
| 1richard1 Member Since: 10 Sep 2019 Location: oldbury Posts: 178
Hi i bought mine not long ago and milage use probably a lot less than most odd popping to shops and taking dogs to local park maybe 2k in miles a year in a 2007 2.7 Hse it had 128k mile on the clock 1 owner from new full FSH just under 7k so far bar service costs and looking to get gearbox flush no more expense than any other motor i have owned, i do live in my works van a transit custom i bought from new 4 years ago which has now 250k miles on the clock and with that have the oil changed at half what the manufacturer recommends no problems so far, bar wear and tear which to be far is very little.
Hi mate thanks for the reply.
| Dave-t Member Since: 18 Jan 2020 Location: Glasgow Posts: 436
you can always get a remap to at least 250 horses |
There not fast fast but surprisingly quick when you put your foot down, saying that if you want quick go for the V8 SC and the noise is better if don't mind the more frequent trips to the petrol station. i get about 18-20 mpg out of the V6, i believe the V8 SC can be under 10 mpg. |
The 2.7 is slow, there's no other word for it. If you're happy to waft aling then it's fine. If you want a bit of poke for the occasional blast or for easy overtaking, then it's lacking.
| james5599 Member Since: 14 Jun 2009 Location: london Posts: 325
This doesn’t sound like it’s going to end well.
Thanks all for your replys, i knew id not get anything newer than perhaps an 07 plate
are most of them petrol or diesel ? |
| Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1849
Keep your eyes peeled on this forum and one will likely turn up followed by a dozen more. The petrols appear to be a lot more forgiving and with the exception of fuel, are cheaper to run. My last service on a 5.0 SC was £200 cheaper than the quoted (independent) cost of the TDV8 (he based his estimate on the TDV8 as he doesn’t see many petrols). I then spent that on replacing the rear brake lines. 2019 5.0 SC SVA (Current)
| DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2025
Get petrol for reasons above and your low mileage
This has to be the most active forum ive ever been a part of! 😀
| All times are GMT |
