![]() | Home > Maintenance & Modifications > Where does this cable go? |
HughN Member Since: 10 Sep 2017 Location: Near Llanybydder Posts: 651 ![]() ![]() |
Same after an hour of 'sleep'. 6.5 A current draw immediately after starting engine, then back to 400 mA after 40 s. Solenoid or alternator? |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5090 ![]() ![]() ![]() |
Alternator I would think.
OvalAutos Member Since: 02 Jan 2019 Location: Cradley Heath Posts: 130 ![]() ![]() |
This cable goes to the starter and alternator. If you're getting a current without the engine running, then the alternator is going to ground. More investigation required...
Thanks.
The [recently changed] alternator was back-feeding. "OEM spec" parts from Euro Car Parts aren't! Not the first to be replaced in the last ten days at the same garage. |
