Home > General (L494) > Deployable side step problem
crasher73
Hi, anyone ever had an issue with drivers side side step not retracting when vehicle is stationary and locked? Likely cause and is it potentially a minor problem with a simple fix? Cheers
Post #594313 Tue Feb 04 2020 12:31pm
Spleen
Happens to me every now and then. I find that disabling the system then turning it back on again solves the issue, either that or manually deploying them occasionally also does the trick. Ferrari F430 Spider F1
MY17 RRS AB V6
2CV6 Special
Post #594393 Wed Feb 05 2020 1:54pm
crasher73
Cheers for the reply. Having only just got the car I've no idea how to do either of these things, is it straightforward?
Post #594397 Wed Feb 05 2020 3:13pm
Spleen
It's in your menu chap:
MY17 RRS AB V6
2CV6 Special
Post #594399 Wed Feb 05 2020 3:47pm
crasher73
Cool, cheers mate Thumbs Up
Post #594400 Wed Feb 05 2020 3:53pm
m13lky
Mine have had a mind of their own from new, I sometimes have to lift suspension to off road full height & clean away leaves to get them to work again, there are supposedly sensors fitted so if you park to close to a high kerb etc they don’t come out & damage themselves, I think leaves, twigs etc that end up under there must give the sensors false readings.
I will just go for fixed ones next, save £2k & a lot of hassle!
Post #594550 Sat Feb 08 2020 4:35pm
