![]() | Home > General > Tracking |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5155
Mine was a bit like that, I simply shortened one track rod and lengthened the other by exactly the same amount, also calibrated the steering angle sensor and now it is spot on. Assuming when you let go of the wheel it doesn't drift to one side.
| McFarTech Member Since: 13 Sep 2019 Location: Kent Posts: 126
Thanks mate. It does feel like it drifts. What I am insure of if its just the camber in the road. sometimes it does not do that.
Can't say for sure calibrating the steering angle sensor actualy had any effect but obviously can't do any harm, if you have a IID tool you can do it yourself or any good Indi. should be able to do it.
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159
If it's a non-constant behaviour i.e., only does sometimes, then I'd suggest it's just a bit of good old fashioned camber following by the tyres. Big tyres are more prone to it than narrower tyres, generally, and these things do wear some big rubber. 2012 SDV6 - it's missing a couple of cylinders
| Tyrefitter Member Since: 19 Jul 2015 Location: Bridlington East Yorkshire Posts: 3677
Laser alignment isn’t the best for these cars,you really need it on a computerised alignment with the car in ttm tight tolerance mode.
I can only speak from personal experience, but this is a printout for the after reading on my car when in UK done by a well known indi in Oxfordshire using Hunter equipment, but the steering wheel was so far off centre I had to take the wheel off and move it a couple of splines on the shaft to get it anywhere near centre although the car drove as straight as a die. I have just replace the lower front arms over here and had to refit steering wheel to original factory position prior to alignment.
| Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1849
Mine was the same as Cols, had the Hunter done but the wheel was off centre, I adjusted the track rod ends by the same amount and it’s now central. The hardest thing is trying to gauge how much adjustment is required. I didn’t want to be adjusting one way and then the other and then back again. 2019 5.0 SC SVA (Current)
It was a little hit and miss but I moved mine by one flat on the track rods and found that was the exact amount I needed to move them, obviously it would depend on how far out the wheel is but I found one flat was a good initial guide to work out how much you need to move it.
| All times are GMT |
