![]() | Home > General (L494) > Front pad change with Brembo |
Dave-t Member Since: 18 Jan 2020 Location: Glasgow Posts: 436 ![]() ![]() |
I’m also just starting the adventure so please carry on. |
ballast Member Since: 20 Jan 2019 Location: MK Posts: 7 ![]() ![]() |
Fronts easy....
RRSporter Member Since: 08 Nov 2012 Location: UK Posts: 61 ![]() |
Just done mine. For balance an absolute pig of a job. Full LR service history. They had put the pins and pads in dry 🤡. No way were they coming out with any punch. A thorough bending of pins then restraighten etc eventually freed them enough to get out. One pad was still completely seized in caliper. Eventually pried out. Cheers Land Rover!!
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4531 ![]() ![]() ![]() |
You shouldn't use copper grease on aluminium calipers |
Mike,while we are on the subject of brakes,I’m going to change both my fronts & rears & im thinking EBC discs & EBC low dust pads,which disc do you recommend as their is a few on the site,Drilled,Drilled & grooved as I’m wanting to match front with rears.Price wise isn’t a issue as I’m wanting to change them before MoT in March as I’m sending it to dealers even though I can do it myself as it’s got MoT insurance,I’ve changed the rear pipes myself last year as I didn’t want to risk them till March. Andy.
Hi Mike Good info for me and others thanks. 👍 I Would have used the supplied red ceramic grease all over but it ran out on the other side so it’s a bit of a mix. To be fair it can’t be worse than nil which Land Rover used on the pins, can it?! 3.0 SDV6 HSE L494 |
The drilled and grooved discs, I've found, can give quite a drone under braking. I've only fitted them to my D3 as it's a huge build, and a bit of willy waving never hurt anyone ![]() Redstuff ceramic pads are indeed low dust, and I rate them very highly, having run them on a little hot hatch, as well as the previous brake setup on my Disco, and I'm sure the 6 pots with Red pads will more than meet my expectations ![]() |
You'd be surprised... The differing metals cause galvanic corrosion, and attacks the pad seats of the calipers. Fine on a steel pad carrier, not ideal on a £600 Brembo caliper x2 In addition, the copper grease seems to attack and swell the rubber dust seals Stick to a ceramic based grease, we use both the Comma version and Mintex, depending on price/availability ![]() https://www.greaseexpert.com/brake-grease-vs-anti-seize/ |
This is the stuff I use on pads & it’s only a tenner on eBay for a 500ml tin which lasts me ages.
Hi Mike. Cheers for the info for indeed all of us. Had already read this article which is the detail on what you say 👍.
They have discontinued red for l494 front brembos. No idea why as they clearly will fit but I wasn’t happy fitting something not approved by the manufacturer. Gone with Hawk instead also ceramic. Will report back any concerns. Less meat on that LR pads that I do know. 3.0 SDV6 HSE L494 |
RRSporter,are the Hawke pads low dust as that’s what I’m after & if so best place to purchas3 them pls. Andy.
Hi Andy
Dave B Member Since: 10 Oct 2019 Location: East/West Sussex Coast Borders Posts: 432 ![]() ![]() ![]() |
Just to confirm, Hawk came from Cambridge Motorsport Parts, Letchworth.
