Home > Maintenance & Modifications > Removing interior trim on 2012+ RRS
B_Tank88
Does anyone have a step by step or a video on how to remove the trim pieces on a 2012 RRS with the rotary shifter. The trim pieces being the 2 console trims, and 1 door card trim on each door.
I've searched the forum but can't find a reference for the later models.
Post #593976 Wed Jan 29 2020 12:04pm
andyslandy
England 2012 Range Rover Sport SDV6 SE Tonga Green
Sounds like a job for youtube.
Post #594033 Thu Jan 30 2020 9:48am
DrRob
Try Powerful UK on yoooo tooooobe * Current: 2024 D350 Defender 90 on coils!
* Current: 1974 Lightweight 2.25L petrol. Old skool
* GONE: 2012 RR Sport HSE SDV6 Orkney Grey. Now being piloted by RRSTDV8
I use www.glenrands.co.uk Great independent specialist!
Post #594048 Thu Jan 30 2020 5:38pm
If you download this file/workshop manual it will have what you need in Section 5 Body Section.
http://www.mediafire.com/file/t7a6drmb6m4i...3.rar/file
Post #594058 Thu Jan 30 2020 10:25pm
Brit Plumber
The centre trim removal involves the removal of the top console which quite straight forward. The door card I found needed fingers of steel because using tools can damage the leather, I have plastic trim tools but even those require careful use. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #594073 Fri Jan 31 2020 11:02am
