Home > Technical > RRS 06 4.2 SC Lean codes |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4790 |
these engines are a bit of a pain throwing lean and rich codes.
Wed Jan 29 2020 6:07pm |
mgrover Member Since: 17 Oct 2019 Location: Leeds Posts: 393 |
smoke test was done with no issues |
Wed Jan 29 2020 6:36pm |
Make sure oil cap is seated correctly to as that can effect the air in the block or it did on mine |
Wed Jan 29 2020 11:15pm |
seems to be sealed correctly but i noticed when i was trying to twist the cap closed the actual pipe twisted as well...could that be it?
Thu Jan 30 2020 10:11am |
Not sure you can try and see if it helps |
Thu Jan 30 2020 10:21am |
bit of an update on this, only thing left is the lambda sensors. i know everyone says they should be functioning fine if their throwing those codes because they've already done a wellness check. but there cheap enough to replace and am almost out of ideas. |
Thu May 14 2020 9:02am |
Themoog Member Since: 27 Apr 2018 Location: Cambridge Posts: 262 |
My 4.2 sc 05 is on lpg and also has the lean mixture codes. I shall follow this thread with interest as I haven’t sorted mine.. |
Fri May 15 2020 10:40pm |
ive done all sorts. supposedly it was VSR due to the lpg, but the heads been rebuilt with hardened valve seats so I doubt its that. i think next ama replace the sensors.
Sat May 16 2020 6:46am |
Everyone said that to me too but was never sure the guy i used to have the lpg serviced checked it and said he could find nothing wrong and t actually ran cleaner on lpg than petrol but he did say if it was fitted and a wire was not connected 100% then maybe it's that what is causing the issue |
Sat May 16 2020 8:13am |
could be. this point am going with lambda sensors though. the lpg system has been looked over by 3 different lpg technicians. |
Sun May 17 2020 5:53pm |
bit of an update to this.
Sun May 24 2020 4:37pm |
another update. it was the maf. i thought it was a denso maf that came with the car, wrong. it was a chinese one and the replacement chinese one i had was no better.
Sun Jun 28 2020 11:59am |
Hopefully sorted then |
Mon Jun 29 2020 8:55am |
