![]() | Home > Technical > Passenger Door Not Unlocking Unless Using Keyless Entry |
Britishlion Member Since: 26 Dec 2019 Location: Cheshire Posts: 11 ![]() ![]() ![]() |
I have the same - any help would be great |
Irving Member Since: 15 Jan 2020 Location: London Posts: 17 ![]() ![]() ![]() |
INteresting... the exact same thing with the keyless entry being ok but remote unlock not working for one door? |
Bigbore Member Since: 08 Jun 2016 Location: Poole,Dorset Posts: 47 ![]() ![]() ![]() |
Ditto that ✔️ RRS SDV6 HSE Orkney Grey,Premium Ebony Black leather,MY12 Autobiography Exterior Design Pack,22"Diamond Turned Rotor Alloys,interior LED's/Number plate,boot LED's x 2,rear entertainment,HD Dash cam,ALIVE Remap,Bumper DRL's |
ptaroni Member Since: 02 Aug 2020 Location: leicestershire Posts: 8 ![]() ![]() |
Anybody sort this? I have exactly the same issue ...Thanks |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 954 ![]() ![]() ![]() |
I'm reading this with anticipation as mine has done this a few times lately,, only the front passenger door is affected. Maybe it's coincidence but when the has happened I've had a suspension fault flash up when I turn the ignition on,, or sometimes just prior to turning off. 2010 RRS, TDV8
mrluke Member Since: 22 Apr 2018 Location: Essex Posts: 270 ![]() ![]() |
Do you have a scan tool ? like SSD software. Mine flags up in there. My rears sometimes fail to open using the keyless , but normally work ok with the fob. Mine is a motor issue . |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5081 ![]() ![]() ![]() |
Had a similar issue recently with o/s rear door would always lock but 50/50 if it unlocked, new lock/latch unit sorted it, not uncommon for different door ones to fail.
