![]() | Home > In Car Electronics > Remote Heater |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 954 ![]() ![]() ![]() |
It will be on the navigation screen, look in the menus and settings for timed climate 2010 RRS, TDV8
Irving Member Since: 15 Jan 2020 Location: London Posts: 17 ![]() ![]() ![]() |
Navigation Screen!! Thanks. That will be the one place I havent looked yet.
I have the remote system on mine,, a small fob whereby I can activate the FBH, ( fuel burning heater) from indoors. These are normally referred to as webasto units. If you don't already have this they can be added, I think you would need a little wiring, a reciever module and a fob of course. Do a search on here for webasto or timed climate and you will find a good bit info. 2010 RRS, TDV8
Aha ok thanks. So when it was advertised it states that its there, but more that its 'capable' as opposed to having the key and unit installed? Obviously you didnt see the advert, but its in the standard autotrader 'this car comes with' spec... |
Bardley Member Since: 26 Jul 2018 Location: Herts Posts: 150 ![]() ![]() |
The D4 side of this forum has a whole host of info. on this..have a read as it explains everything. If you don't have the remote start for the FBH, there will be someone that can enable it for you.
That is really helpful, thank you |
WISKR Member Since: 19 Mar 2020 Location: Essex Posts: 12 ![]() ![]() ![]() |
Hi, I have also recently purchased a RRS and the spec says it has a fuel burning heater. There is nothing on the sat nave or elsewhere to enable it from a timer. Also no key to operate. Any ideas how I can tell if I have the electronics to use a key fob? |
Is it definitely an autobiography with the heater as part of the package? |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5101 ![]() ![]() ![]() |
Does the Timed Heating aspect of the FBH need to be activated in the CCF files first by any chance? The A/B had park heating and remote control as standard and the HSE it was a option according to the sales brochure. There are a couple of pages 60/61 in the Owners Handbook on how to access and set it via. the home screen menu.
Hi it’s an HSE. I needed to ask Land Rover for the spec for something else and it says fuel burning heater on the spec. I looked through the manual and accessed where it says on the screen but there is nowhere that’s shows the functionality. I assumed it needed the remote. But reading some other info I am now not sure if it just means the heater is there but the receiver and fob and the system needs programming to use it. I don’t want to buy a remote fob and the find I need to spend a few hundred pounds have all the rest done. |
To see if you have the module, just look behind the panel in the right hand side of the boot...
Thanks for this. I’ll take a look |
pjbracer1 Member Since: 25 Aug 2014 Location: Southampton Posts: 413 ![]() ![]() |
Hi all
How strange. Mine never steams the car up and it runs every day. Kev
