Home > Wheels & Tyres > TPMS
blueanchorinn
TPMS
I’ve took my 22s off and replaced with 20s with GG AT3 on but no TPMS valves. I’m getting TPMS fault and the amber triangle each time on startup. If I get some valves and have them fitted will the car find them or will they need pairing.
Thankyou in advance
Post #593324 Wed Jan 15 2020 1:19pm
FrankH
United Kingdom 2013 Range Rover Sport SDV6 HSE Santorini Black
Tpms
The car will find them, I have two sets of wheels and the car just pairs with them all by itself. L494 2016 model.
Post #593355 Thu Jan 16 2020 8:19am
blueanchorinn
Thankyou
Post #593357 Thu Jan 16 2020 8:47am
Tyrefitter
If you still have your original wheels you could remove them & refit in new wheels,any one with a tyre machine can do them as you only need to break the outer bead,easy enough job. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #593359 Thu Jan 16 2020 9:07am
blueanchorinn
Thanks for your reply but I’m being greedy and having two sets 😂. One for road and one for winter/playing
Post #593365 Thu Jan 16 2020 11:09am
Tyrefitter
Good idea,you can just purchase another set from that well known selling site just make sure the serial numbers correspond as ive known folk get them & not worked. Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #593366 Thu Jan 16 2020 11:39am
blueanchorinn
Serial numbers correspond?
All worked fine for a few miles. Found the new tyres then got the TPMS fault. Now get all the time 🙄
Post #595624 Wed Feb 26 2020 8:59pm
Tyrefitter
could the tyre fitter have damaged a sensor fitting the tyres as the tyre has to be in a certain position on the tyre machine so they don’t get damaged. Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #595627 Wed Feb 26 2020 10:14pm
If it was just one sensor would the system not say which wheel position it was?
Post #595629 Wed Feb 26 2020 10:23pm
blueanchorinn
It’s unlikely he has damaged all four and it did work for a few minutes
Post #595645 Thu Feb 27 2020 10:28am
Tyrefitter
im guessing wrong sensors. Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #595651 Thu Feb 27 2020 11:27am
blueanchorinn
Bought from a long established indy who took the reg no so I’m hoping they are the right ones and why would they of worked for a while?
Post #595660 Thu Feb 27 2020 4:01pm
If you have two sets of wheels, I realise it's a bit of work but is it worth re fitting your original wheels to see if the car is finds them ok. if it does it indicates sensors, if not then possibly the problem is the car system itself as the new ones worked originally for a short time and purely coincidence it played up after fitting the new wheels/sensors. Only a suggestion.
Post #595685 Thu Feb 27 2020 9:28pm
blueanchorinn
I’ll get SWMBO on it at the weekend. Thanks all
Post #595741 Fri Feb 28 2020 4:46pm
