Home > In Car Electronics > Internal accessories power socket |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4843 |
I'm sure they power down a short time after ignition is switched off, If you do a search I do vaguely recall a post where someone has modified them to be live all the time.
Thu Dec 26 2019 12:00am |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1061 |
They go on and off with the ignition. 07MY RRS TDV6
Thu Dec 26 2019 12:39am |
Had a quick look to see what mine actualy did, they power up by opening the door but have to turn ignition on or they will power down again after couple of mins. switch the ignition off and they power down after two/three mins. if you turn the ignition off and lock the doors they power down straight away.
Thu Dec 26 2019 4:31am |
derekmines Member Since: 22 Apr 2019 Location: MELKSHAM Posts: 133 |
Yep, as noted above they power down with ignition...
Sun Jan 05 2020 11:36am |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1138 |
There are several permanent live unused fuses in the internal fusebox under behind the glovebox. Fuses 18, 28, 29 and 33. Kev
Sun Jan 05 2020 5:05pm |
That's really useful to know, cheers.
Sun Jan 05 2020 5:09pm |
It certainly is derek. Just open the glovebox, push the stays inboard and the glovebox will hinge down into the footwell exposing the fusebox.
Sun Jan 05 2020 5:17pm |
Awesome news... I can't tell from the pics, are they mini blade fuses or standard sized ones?
Sun Jan 05 2020 8:55pm |
denny111 Member Since: 07 Dec 2014 Location: Kent Posts: 98 |
Hi
Wed Jan 08 2020 10:46am |
Thanks for this, the tap has now arrived so I shall see about doing this project over the weekend. |
Fri Jan 10 2020 12:20pm |
Glovebox disassembled as noted, next job is to find a route for the power cable from the fusebox area to to driver's side... this look as though it might be entertaining! |
Wed Jan 15 2020 1:10pm |
