Home > General > filling issue
john.m
United Kingdom 2008 Range Rover Sport TDV6 HSE Lux Izmir Blue
filling issue
My sport takes an age to fill with diesel, £2 then cuts off the pump.
This continues until its full, I can hear the diesel coming to top of the neck of the filler, then click it stops again.
I have put an endoscope down the filler cap, this is what I found.
Does anyone know what it is, should it be closed?
Any thougould I would be grateful.
Its about 3 feet down the filler neck
 2008 range rover sport 2.7 hse
Post #593145 Sat Jan 11 2020 10:30am
Disco_Mikey
That's the anti-syphon plate in the fuel tank
Take the filler pipe off the back of the tank, and make sure the flap moves. If that's OK, you have another, be it a blocked breather or pipe
Post #593146 Sat Jan 11 2020 10:55am
Dave B
I have a yellow plastic device in my tool kit that unlocks the filler, when it has become closed/locked if trying to put petrol into the tank. Don't know how it works, but it is covered in the handbook.
Could this be what has heppened, ie. someone has tried to put petrol into it?
Dave 2010 3.6 TDV8 HSE (Gone)
2011 Discovery 4 Commercial SDV6 (Gone)
1980 OBLIC 4.0ltr Range Rover (went a long time ago)
Post #593147 Sat Jan 11 2020 10:56am
Disco_Mikey
Pre facefilt cars don't have the yellow misfuel prevevention thing Thumbs Up
Post #593149 Sat Jan 11 2020 11:12am
john.m
Thanks, what I will try is putting the camera back in and gently push a hose down it to see if it moves.
I will be gentle as the hose may push past the flap and get stuck on trying to remove it.
Or is it quite easy to get access to the flap. 2008 range rover sport 2.7 hse
Post #593161 Sat Jan 11 2020 4:25pm
Disco_Mikey
Very easy to access, with the fill pipe disconnected underneath
Post #593163 Sat Jan 11 2020 4:37pm
john.m
Thumbs Up 2008 range rover sport 2.7 hse
Post #593177 Sat Jan 11 2020 7:29pm
