Home > Technical > RR sport - CRUISE CONTROL issue
nil07
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Bonatti Grey
So guys I have noticed for the whole of today that when I try to put on my adaptive cruise it’s says “cruise control unavailable”
I have cleaned the black plastic strip at the front where the parking sensors are.
Incidentally I went into a small bollard yday in a car park around 2 mph. No major damage just 2 little scratches in the black plastic strip.
Could fault be related to this little knock ? Or is it one of these software glitches ?
Car is only 2 weeks old 😔 N
E46 M3
X6
2015 RRS HSE dynamic
2018 RRS Autobiography
2019 SVR
Post #591969 Tue Dec 17 2019 6:11pm
Eaters
The Adaptive Cruise Control sensor is not in the bumper strip with the parking sensors. It is above that (and just above the number plate) recessed in the lower air intake towards the passenger side of the car
http://www.rrsport.co.uk/gallery/albums/us...ontrol.pdf
Could your "little knock" have damaged this area?
 Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #591993 Wed Dec 18 2019 8:35am
nil07
I mean you would find it very hard to identify any damage so I would be very surprised if this was the cause from the little knock. N
E46 M3
X6
2019 SVR
Post #592045 Wed Dec 18 2019 11:59pm
Is this on your SVR? The sensor is likely in a different position to the one Eaters has shown which is for the original RRS ACC sensor. 2012 SDV6 - it's missing a couple of cylinders
Post #592058 Thu Dec 19 2019 10:19am
nil07
Yep on the SVR
Also on start up says Emergency Intelligent Braking not available
Maybe it’s same unit ?
N N
E46 M3
X6
2019 SVR
Post #592072 Thu Dec 19 2019 1:39pm
aaronjb
Yep - would expect the anti-rear-ending to be based on the same forward facing radar sensor as the adaptive cruise (certainly was in my Skoda) 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #592073 Thu Dec 19 2019 2:01pm
nil07
Jet washed the car thouroughly but still the goddam cruise and intelligent emergency braking not working
.... trip to dealer I guess in the NY N
E46 M3
X6
2019 SVR
Post #592306 Tue Dec 24 2019 12:19am
Gerd1986
United Kingdom 2012 Range Rover Sport SDV6 Autobiography Santorini Black
Where have you installed your dashcam?(you mentioned it in another thread) If behind the rear view mirror, try turning it off and see if that resolves it. I had to place mine to the left of the mirror mount rather than underneath it as it interfered with my ACC and high beam assist.
Post #592307 Tue Dec 24 2019 12:30am
nil07
So I didn’t have the issue on install of the dash cam
But good point
I have installed mine to th right of the mirror in the hatched area N
E46 M3
X6
2019 SVR
Post #592308 Tue Dec 24 2019 12:35am
Gerd1986
Mine didn't interfere on install, only happened after a while. Went to the garage as I couldn't find the problem, they turned the dashcam off and everything worked again straight away.
Worth a try anyway.
Post #592309 Tue Dec 24 2019 12:39am
nil07
Thanks Gerd..will try today ... is it the actual dashcam signal or the obstruction that was causing it ? N
E46 M3
X6
2019 SVR
Post #592320 Tue Dec 24 2019 10:15am
Gerd1986
It seemed it was the signal for some reason, as though the sensor in the windscreen is directed downward, therefore when mounted below something from the dashcam interferes with the signal. When mounted to the left and higher it seems as though it doesn't block the signal. Could be complete BS, just know it worked for me.
Post #592321 Tue Dec 24 2019 11:05am
nil07
Disconnected it and sadly still comes up
Will give it a bit
More
Time just in case N
E46 M3
X6
2019 SVR
Post #592323 Tue Dec 24 2019 12:55pm
nil07
Will give it a bit
More
Time just in case N
E46 M3
X6
2019 SVR
Post #592324 Tue Dec 24 2019 1:01pm
Boxers
United Kingdom 2007 Range Rover Sport TDV8 HSE Zermatt Silver
Had exactly the same thing happen in my 2007 TDV8 two nights ago saying cruise not available never had any problems before got in it today & it's working normally again any ideas as to why ?
Post #592380 Thu Dec 26 2019 8:10pm
