![]() | Home > Maintenance & Modifications > Smoke under bonnet when engine off |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1543 ![]() ![]() ![]() |
Not sure if this is of any help, and you've probably covered it already, but if smoke is still there after the engine is off, it would suggest a fluid leak hitting somewhere hot. I'd be looking for obvious signs of a leak. What colour is the smoke? Robin
dangermousehouse Member Since: 01 May 2009 Location: Cairns Posts: 32 ![]() ![]() |
Colour is difficult to say. Maybe a beigey sorta colour. Definitely not black, maybe similar to thin wood smoke.
You can load to You Tube and then provide the link. I think that's how most on here do it Robin
Barryp Member Since: 05 Nov 2011 Location: Sydney Posts: 261 ![]() ![]() ![]() |
If its from the back of the engine the exhaust crossover pipe is there, have a search for issues in that area.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9078 ![]() ![]() ![]() |
TDV8 doesn't have a cross over pipe.
PCC?
Sorry, should have been PCV so yes the crankcase ventilation.
Dangermouse, couldn't see that it was a v8 as not in your profile that I could see.
