Home > Oval Autos > Seized steering column
OvalAutos
Site Sponsor
Lots of chatter about seized lower steering column UJ on here. So we thought it might be helpful to demonstrate what we do to free them up instead of replacing the column for a couple of hundred quid.
If you don't have access to a hot wash, you can always borrow a large saucepan from SHMBO and boil the joint on the cooker. Good luck with that Rolling with laughter
We recommend Kent Rusty Penetrating fluid.
Joe
Those in the know, know. Those that don't know, just need to ask.
Facebook: Oval Autos
Twitter: @Ovalautos
Instagram: OvalAutos
Web: www.OvalAutos.com
Post #592120 Fri Dec 20 2019 11:24am
Bustanut
Thanks chaps, cracking video. Just replaced with new on mine. Don't suppose you have any tips on removal/replacement.
Post #592122 Fri Dec 20 2019 12:06pm
OvalAutos
Site Sponsor
Remove the tray cover by the brake fluid bottle. Take off the side panel and base section nearest the engine (3x 13mm nuts). You should now be able to see the top of the column. Turn the column so the bolt points upwards for easy access. It will either have a 10mm bolt or E10 torx. Undo the bolt and slide the column downwards, off the upper column.
As a precaution, you can use a bungee strap to hold the steering wheel to avoid accidentally turning the wheel and damaging the clock spring.
Now either jack up the front of the car or up on a ramp.
Remove the metal engine under tray to gain access to the lower part of the column. You'll see a bolt the same as the top one just under the UJ. Undo this bolt and now you can slide the column up and off the rack. A little wiggle and out comes the column. You don't need to mark the column as you can't get it wrong when you reinstall it.
Now follow the freeing procedure and then refit the column. Using new bolts, tighten to 25Nm .
Joe
Twitter: @Ovalautos
Post #592124 Fri Dec 20 2019 12:48pm
Bustanut
Thanks Joe, i could see the bolt at the bottom but not at the top as it was hidden under they tray.
Post #592128 Fri Dec 20 2019 4:27pm
Site Copyright © 2005-2020 Futuranet Ltd & Martin Lewis
