![]() | Home > Technical > Front wheel bearing - DIY? |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 782 ![]() ![]() ![]() |
https://disco3.co.uk/forum/topic116658.html
SomersetRRS Member Since: 18 Nov 2019 Location: Somerset Posts: 65 ![]() ![]() ![]() |
Thanks Oldandconfused. That's the perfect information I needed. Looks very doable. |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9060 ![]() ![]() ![]() |
1. Don't buy cheap bearings.
So steer clear of the Britpart and Bearmach bearings? |
It's the age old adage,,,you only get what you pay for 2010 RRS, TDV8
aaronjb Member Since: 26 Jun 2019 Location: Northampton Posts: 447 ![]() ![]() |
You "may" need a 3-leg puller to get the hub off the axle, in lieu of the LR Special Service Tool, and then draw the axle back in with the hub nut - again, in lieu of the SST.
Thanks, Aaron. I have a puller so should be sorted there. Looks like Timken is the way to go. Mine is making no noise at all, just noticable play when the wheel is off the ground so whilst it needs sorting, I don't think it's imminently going to disintegrate.
My off-side was noted as having play at the MOT, but I'm pretty sure it was the near-side making all the groaning noises (because the noise went away when turning left, taking the stress off the near-side).. made a nice Christmas bill to go with the one from HMRC, anyway |
PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 402 ![]() ![]() |
A handy tip is using a SDS hammer drill and a blunt chisel bit, set the drill to hammer action only and use that to force off the hub once the shaft has been removed.
david007 Member Since: 20 Jun 2017 Location: Forfar Posts: 166 ![]() ![]() ![]() |
This might be useful for a bit of research.
Hog Member Since: 03 Dec 2015 Location: Wassenaar Posts: 254 ![]() ![]() ![]() |
It's no fun job to get the old bearing out, unless you got the OEM JLR tools. Can be a pain in the neck. Be prepared! RRS 3.0 SDV6 HSE Lux RRS 3.0 TDV6 gone LR 3 HSE V8 gone DiscoveryII V8 Gone Discovery 1 V8 Gone Mustang Shelby Alfa Guilia (classic) |
