Home > Maintenance & Modifications > Dr Tranny & the Dodgy Torque Converter
CornishRob
United Kingdom 2006 Range Rover Sport TDV6 HSE Sumatra Black
Sounds like and episode of Scooby Do, but after procrastinating for about 18 months on whether to add the Dr Tranny lube guard, I finally added it to the box on my MY06 TDV6. The early indications are that it's done the job. Generally much smoother, and no judder up hills or when under load.
I haven't tried it up anything really steep, but in all the usual places that it used to do it, it's very smooth. Even the wife noticed it this morning.
The only reason I added it was because I didn't think a £3K new gearbox was a good idea on a car worth £4K - £5K, if I wasn't going to keep it. However, I still really like my RRS, and having had it nearly 5 years, I've long ago fixed all the things that previous owners should have kept on top of (gearbox excepted). So I thought I've not got anything to loose, if it doesn't work.
Anyhow, I'll give it a bit more time to be certain, then I'll change the air struts, as after 139,000 miles, the ride is a bit crashy now. Very Happy
Just thought I'd add another recommendation for this stuff.
(BTW, I added it by driving up my ramps on the drivers side, front and rear, to tilt the car over, then with the engine running, nothing comes out of the drain plug, so it's easy to squirt in.)
Post #590515 Sun Nov 17 2019 2:02pm
Now there is another method for adding it. Laughing
Sounds harder work though.
Post #590516 Sun Nov 17 2019 3:08pm
HughN
Wales
I've just paid £1,200 for supply and fitting of a new OEM torque converter. The same company quoted £2,100 for a recon box. Some of the best money I've spent on the car - smooth as anything. They are a bit too far from you, though... Wink
Post #590518 Sun Nov 17 2019 3:42pm
CornishRob
Yeah, I did think about just getting a new box, but Mrs Cornish needs a new(er) car (two door soft tops are not easy to get grandhildren in the back!), so thought it would be worth a go
Post #590538 Sun Nov 17 2019 10:48pm
knwatkins
Re: Dr Tranny & the Dodgy Torque Converter
What a good idea! Laughing Kev
Post #590756 Thu Nov 21 2019 7:48pm
it's the level plug on the side, just incase anyone else was thinking of following this Rolling with laughter
Post #590812 Fri Nov 22 2019 1:54pm
Devon Z
England 2005 Range Rover Sport TDV6 HSE Java Black
How much do you add? Conflicting info on the Dr Tranny website. Steve
2005 2.7 TDV6 HSE, ongoing project.
1998 Volvo V70 R auto FWD, Back on the road again.
1999 BMW Z3 (owned from new) garage queen.
Post #591223 Fri Nov 29 2019 11:18pm
CornishRob
I bought two tubes, but only added one. This seems to have worked fine. Thumbs Up
Post #592015 Wed Dec 18 2019 3:53pm
1richard1
The big question is how did you drive the RRS to get it on both ramps they are good but that is above and beyond Shocked
Post #592018 Wed Dec 18 2019 5:59pm
DrRob
Did you think about a Megaflush? * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
I use www.glenrands.co.uk Great independent
Post #592019 Wed Dec 18 2019 5:59pm
triplemmm
I added two tubes a few years ago. Curedthe shudder completely.
It came back a bit after having a mega flush, although not often noticable. Revs stay constant when it does judder so don't think its the TC on mine. Might add another tube of Dr Tranny.
Seems really good stuff
Post #592041 Wed Dec 18 2019 11:12pm
CornishRob
It was quite easy really. Raise the suspension to Off Road height, put the ramps in front of the drivers side wheels and drive up 'em! I used to use low-range, but it can be a bit jerky as the gearbox bites.
Yep, I had it done about a year ago, it helped a little, but not much.
Post #592054 Thu Dec 19 2019 9:38am
Dr Tranny doesn't cure the problem it just helps mask the symptoms. The torque converter lock up clutch will need replacing as it gets contaminated with gunk in the transmission fluid. Obviously if you have a flush after adding the Dr Tranny, you remove the Dr T and the symptom comes back.
The best course of action is to have an early flush (at 50k miles) and then do it again every 50k miles. For those buying second hand RRS, the likelihood is that the early flush isn't done so the first you know about the TC issue is when the symptoms start. 2012 SDV6 - it's missing a couple of cylinders
Post #592059 Thu Dec 19 2019 10:24am
Devon Z
Just put one tube in mine as a precondition, had mine two months it had a slight judder under acceleration when I test drove it and the dealer said he would sort it out. A Land Rover specialist done a fluid change for them and it’s been fine but I want it to stay that way so I popped one tube in (got two tubes so may do another change in the future) it certainly has smoothed the low speed gear changes out markedly though I haven’t driven that far yet. Steve
Post #593457 Fri Jan 17 2020 11:37pm
DrRob
Wayne is spot on with this advice. Have it done as a part of a preventative maintenance programme before any symptoms appear then at regular 50K intervals Thumbs Up Had my Full Fat Megaflushed by Bodsy at 85K. No symptoms before or after. That’s what you want Bow down Thumbs Up * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
Post #593462 Sat Jan 18 2020 9:07am
