Home > Technical > Battery drain |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4799 |
I would recheck the big J fuses under the bonnet. |
Sun Dec 15 2019 6:28pm |
rover75 Member Since: 14 Mar 2019 Location: On my way Posts: 109 |
hello there
Sun Dec 15 2019 9:17pm |
G carrington Member Since: 15 Dec 2019 Location: Channel islands Posts: 5 |
Well I think the alternator is disconnected
Mon Dec 16 2019 8:49pm |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 750 |
https://www.disco3.co.uk/forum/robbies-gui...19574.html
Tue Dec 17 2019 11:49am |
this is worth looking at too.
Tue Dec 17 2019 7:09pm |
Hi Andy I have pulled out all the j fuses and there was still the same drain 4.6amps
Wed Dec 18 2019 11:48am |
So if you have removed all the large J fuses under the bonnet, without a drop, and the thick cable to the engine.
Wed Dec 18 2019 8:17pm |
Clive.240 Member Since: 10 Dec 2018 Location: Mid-Wales Posts: 4 |
Did you sort out your battery drain issue I am having similar problems just got a clamp meter so will start investigating this weekend |
Thu Jan 07 2021 12:21am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4856 |
Unfortunately people come on to the forum and ask questions about a issue or fault, are given suggestion as to the problem by members then appear to be reluctant or cannot be bothered to come back to say if they have resolved the issue or not, which may also help others members, until they have another problem and do exactly the same.
Thu Jan 07 2021 2:56am |
Thu Jan 07 2021 1:43pm |
Guyzer73 Member Since: 04 Jul 2009 Location: Muscat Posts: 852 |
Hi Col, I have the same battery drain problem... If I pull Fuse 13 passenger to disconnect the heated rear screen, will this also disable the upper tailgate switch or is this separate? I can't find a suitable fuse for it. Cheers Guy 2006 RRS S/C CONSTANTLY under modification... 1994 RRC 4.2l not LSE sadly gone but not forgotten LR Defender 300Tdi - affectionately know as "The Black Beast" |
Mon Aug 02 2021 11:58am |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8851 |
I don't think it has a separate fuse of its own - it's part of the overall locks and latches etc. The simplest thing might be to just disconnect the switch and see if the drain disappears or not. 2012 SDV6 - it's missing a couple of cylinders
Mon Aug 02 2021 12:25pm |
Cheers RRSTDV8,
Mon Aug 02 2021 12:53pm |
Pull the switch plug on its own, of course, not at the same time as the fuse. That way you know which is the issue. 2012 SDV6 - it's missing a couple of cylinders
Mon Aug 02 2021 2:02pm |
