Home > Detailing & Car Cleaning > Maguiars ceramic wax. |
whippetman Member Since: 12 Jun 2010 Location: on the level Posts: 497 |
Sat Aug 17 2019 7:02am |
RRT Member Since: 26 Mar 2018 Location: South Coast Posts: 236 |
I have been discussing Meguiars on a Facebook group and I am told this product is even better and cheaper:
Sat Aug 17 2019 6:44pm |
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 864 |
Not sure about this one Tried it today but after drying the car there appeared to be quite a few streaks, especially on the glass. Needed quite hard rubbing for them to disappear. I wont dismiss it out of hand but will use it again to see if it improves, or its back to Meguirs last touch which can be added in around 5 minutes. It is a true spray on wipe off |
Mon Aug 19 2019 12:41pm |
Lindab,if you already have protection on the car you are supposed to spray on they powerwash off to spread the product then dry car with drying towel,,Have you not watched the video I posted Andy.
Mon Aug 19 2019 1:14pm |
Andy, did it as per the video. Thought I might as well do it as instructed Not like me It seems fine now. As I said, will try it again next wash & see what it turns out like. |
Mon Aug 19 2019 5:47pm |
jd2uk Member Since: 01 Apr 2017 Location: Kent Posts: 109 |
I used this on a black car for the first time on Sunday and was very impressed. I sprayed it on and wiped it off and didn’t have any issues with streaks. I watched a few videos and was very careful not to apply too much. It will be interesting to see if subsequent applications which are rinsed off will look as good.
Mon Aug 19 2019 6:57pm |
Bill Portland Member Since: 01 Feb 2017 Location: Dorsetshire Posts: 387 |
i used the maguiars ceramic wax for the 1st time on sunday, using the instructions on the bottle rather than the video (dried off rather than rinsed off for the 1st time use) and was impressed with the results, especially on the rather extensive areas of black plastic on my car (jimny). I did have quite a lots of "streaks" but they cleaned up easily enough. trouble was, that evening i drove through an area where it had been raining but had stopped and so the paintwork is now coated with that nasty dotty grey road spray stuff. Even the best finishes cant stop that and i guess it will have killed any water shedding propoerties until I clean it again. Merc C220 estate Sport AMG
Tue Aug 20 2019 10:13am |
After my moan previously about streaks, tried it again yesterday. This time it came out perfectly well, no streaks |
Mon Sep 09 2019 7:22am |
nil07 Member Since: 05 Apr 2015 Location: london Posts: 115 |
Andy - when do you use this product ?
Thu Oct 31 2019 11:24pm |
I use it after the fast finish. Andy.
Fri Nov 01 2019 12:29am |
So fast finish THEN the meguiars ceramic wax?
Sat Nov 02 2019 9:39pm |
Devon Z Member Since: 22 Sep 2019 Location: Brixham, Devon Posts: 313 |
I’ve also seen the vids and I am a fan of Maguiars products. Steve
Fri Nov 29 2019 6:39pm |
so im gonna apply the BASE COAT for the hybrid ceramic wax. does that mean I also happy to apply the maintenance coat straight after ?
Tue Dec 10 2019 1:26pm |
Spangler Member Since: 02 Mar 2019 Location: Kent Posts: 98 |
That's exactly what I did at the weekend - after applying the base coat and wiping off you then wet the panels (starting from the roof) spray it over sparingly and then rinse off with a pressure washer. I used a claybar over the car before the base layer just to ensure the wax had a smooth foundation to stick to but that's not a necessity.
Tue Dec 10 2019 4:15pm |
