![]() | Home > Technical > Not Locking |
Stand Easy Member Since: 10 Aug 2016 Location: Manchester Posts: 126 ![]() ![]() ![]() |
From what I recall those 2 bleeps suggest something isn't shut, tailgate, another door, bonnet. Bonnet catches are regular for showing up when alarm bleeps. |
Tiny Timmy Member Since: 20 May 2011 Location: Bucks Posts: 233 ![]() ![]() ![]() |
Thanks ive tried shutting everything again, sometimes works sometimes doesn't !! Im thinking its a sensor somewhere?? |
Duc750 Member Since: 27 Mar 2019 Location: Northampton Posts: 158 ![]() ![]() |
this was a precursor for our boot latch failing earlier in the year 2012 SDV6 HSE (technically its hers)
Ah better have a look into that . How can you tell if it's that? The boot seems to lock ok at the moment . |
check the bonnet catch on the drivers side, (RHD) this is often the cause, it'll appear the bonnet is shut but the alarm system says not |
Thanks stand easy, I have had trouble with that before, but ive slammed it shut and it still does it now and then.
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1054 ![]() ![]() ![]() |
Its pish easy to take out and clean, save yourself the frustration. |
Cheers I'll give it a run |
It's stops opening. Randomly initially and then with monotonous regularity. 2012 SDV6 HSE (technically its hers) 2000 D2 TD5 - definitely mine 2005 D3 V8 Metalian Camper trailer for adventures |
Boxers Member Since: 26 Sep 2019 Location: Lincolnshire Posts: 225 ![]() ![]() ![]() |
Had my alarm go off whilst parked in the drive for no apparent reason plus had the bonnet open message displayed 3 or 4 times, googled the problem and they recommend & show how to clean the switch if that fails looks a simple job to replace. |
