![]() | Home > In Car Electronics > Luggage Compartment Accessory Socket |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1543 ![]() ![]() ![]() |
It may be different on a 2013 model from my one but have a look at fuse 47 in the glove box fuse board. Robin
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5068 ![]() ![]() ![]() |
don't these have a fuse box in the boot ? on the right side |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5082 ![]() ![]() ![]() |
Could try this one.
Rainbow Member Since: 14 Jul 2014 Location: UK Posts: 67 ![]() ![]() |
Thanks for taking the time to reply. Fuse 47 has a different designation but I did check if it was blown. I had checked fuse 53 as that is indicated to be the fuse in the manual. However that is not blown. I replaced with a new fuse to double check but still no power. I checked all the 20a and 15 fuses in the luggage compartment and none were blown. It was a good test of the tracker though as I had a call from the InControl monitoring centre. |
