Home > Faults & Fixes > 2.7 V6 WONT START BELOW 0 DEGREES
JD1579
United Kingdom 2006 Range Rover Sport TDV6 HSE Stornoway Grey
Having the same issue as last year... Now the cold mornings are here in the UK every time the temperature drops below 0 I have a job starting the car in the morning. I replaced battery last winter and there is nothing wrong with that. I found a trick on youtube putting warm water on a certain part (under the main engine bay) but this means taking off the oil cap and faffing about. Plus don’t know if it’s a good idea Laughing Any solutions??! PLEASE
Post #591270 Sat Nov 30 2019 7:39pm
Oldandconfused
Could be the glow plugs have failed. By all accounts a right pita to change with danger of them snapping meaning cylinder heads off. You would probably want to have them checked. Someone, Robbie?, did a great post on the Disco3 forum, maybe in the wikki
Post #591271 Sat Nov 30 2019 7:54pm
Disco_Mikey
Glow plugs are at fault
Post #591280 Sat Nov 30 2019 10:29pm
