![]() | Home > General > Car banging into gear after gearbox refurb |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5134 ![]() ![]() ![]() |
probably a crack in clutch drum, so I would keep fighting them.
Flatteraxe Member Since: 23 Apr 2014 Location: Leicester Posts: 43 ![]() ![]() ![]() |
Before the refurb I had a slight knock in gears 2>1 but I also upon inspection had burnt transmission fluid in the box and the dreaded 'F' for gearbox fault came up when driving once. It was decided that the box should be overhauled.
its not the TC. |
There’s no way it’s normal. These things should be seamless with just a change in engine tone and rev counter movement. 2006 2.7 TDV6 HSE in Cairns Blue. |
PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 402 ![]() ![]() |
The only time when mine "Jolts" is when chainging down in sports mode from 2nd to first just before i stop. at no other time does it "jolt" so definatly not normal. |
Thanks for the replies guys. In a different car if this was to happen I would say the engine mounts have broken, it can be that severe. I have messaged the garage back and I'm waiting for a response. |
Boxers Member Since: 26 Sep 2019 Location: Lincolnshire Posts: 225 ![]() ![]() ![]() |
Definitely doesn't sound right I have exactly the same as yours , only had it a couple of months & you cannot even feel the gear changes, don't let them fob you off. |
