Home > General > DRL when lights on Auto
Just throws up codes BB124A-15 and B124B-15 open circuit but no working drl's if I remember right.
Post #590787 Fri Nov 22 2019 9:12am
Brit Plumber
That’s them,
I suppose that there will be 2 unused feeds from the BCM for these options. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #590792 Fri Nov 22 2019 9:42am
knwatkins
Stu wrote:
i don't know if the DRL's are different on a RRS to a FFRR, but the lights look the same! I used my IID tool to set the DRL's to one of the other settings Canadian/Scandinavian and that turns them on all the time also. Is this not possible on a RRS? seems much easier than messing about with wires.
Scandinavian and Canadian CCF settings puts dipped beam on Stu. The aim is to put the sidelights on only. This simply cannot be achieved through a CCF change.
It takes less than 10 mins to unplug the fuses and push the cables in, so this mod really isn't that much effort. Kev
Post #590794 Fri Nov 22 2019 9:43am
idi
Just tried this. Took about 5mins and works great. Thanks!
Post #590870 Sat Nov 23 2019 3:32pm
knwatkins
Well done. It makes a difference. Also adds a small increase in safety too. Kev
Post #590871 Sat Nov 23 2019 3:46pm
Tim in Scotland
There is a reason why these lights are set up the way that they are........ they are not DRL’s they are what LR calls Signature headlights. In 2010 DRLs were not the law for new cars like they are now, they are not bright enough to qualify as DRLs IIRC they are purely for aesthetics because owners were (including me) modifying our headlights with strips of LEDs in the units to copy Audi and BMW at the time. It was a very popular DIY mod back in 2008/2009 so for the facelift LR tried to kill the aftermarket accessory lights makers!
This is what I had Hawke do to my units - note also the tiny LED side lights too, these are the adaptive units with the kerb marker spot light above the sidelight lamp.
Another mod to the lights back then was to enable the vertical USA side markers lights in the orange reflectors - for the UK market LR fitted the USA side marker reflector units but didn’t put a lamp inside them, if you remove one of the long thin reflectors you may well find it has a lamp holder in it!
 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #590895 Sun Nov 24 2019 1:09am
knwatkins
Yes I completely agree Tim. The LED sidelights/fairy lights are no where near as bright as DRLs. However, they do make you slightly more visible than no lights.
Concerning the side markers, was it just a simple case of inserting bulbs into the bulb holders? Kev
Post #590901 Sun Nov 24 2019 8:42am
Tim in Scotland
On the pre-facelift cars, IIRC yes I don’t know about later models. I did it on my 2007 TDV8 as well as changed the side repeater indicators to clear covers with orange lamps in them. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #590931 Sun Nov 24 2019 6:12pm
idi
I added a switch to mine earlier today too. I wanted it to be easily accessible though so I can easily turn it off/on without having to drop the glove box. So I fitted the switch to the top glovebox at the back.
Post #591840 Fri Dec 13 2019 6:22pm
knwatkins
That's good. How do you get the top glove box out? I tried once, got frustrated then gave up! Laughing Kev
Post #591841 Fri Dec 13 2019 9:00pm
idi
Didn't have to take it out luckily. I wired the switch up before hand and there was enough space around the back to just about squeeze the switch in. Took me about 20mins to get it in though, but worth it
Post #591851 Sat Dec 14 2019 12:09am
jason-nike
I added DRL rings to my old one and wired them up to come on with ignition and go off when ignition turned off
Post #591870 Sat Dec 14 2019 4:10pm
G carrington
Guernsey 2006 Range Rover Sport TDV6 HSE Santorini Black
Hi all just joined I am Graham carrington from Guernsey in the Channel Islands
I have a rrsport 2006 hse 2.7 v6 with problems 😂😂😂
Post #591898 Sun Dec 15 2019 2:25pm
Abandito
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Rimini Red
Great work to those for coming up with and sharing this simple mod
Finally did mine over the weekend, really simple except for tight space in fuse box, really love the outcome
Thanks guys
Post #618175 Mon Oct 18 2021 6:23pm
Mosdefinitely00
United States 2013 Range Rover Sport Supercharged Autobiography Bonatti Grey
Late to the show
Apologies for being late to this thread - I made the change to the fuse box mod wiring and now am getting the adaptive light error showing up on my dashboard. Wondering if I also need to change the cff settings to Scandinavian using the IDD tool? I don’t have one as of now and was hoping I’d be able to get the DRL daily lights without the tool. Any guidance? Thank you. [/quote]
Post #625185 Mon Jul 04 2022 6:13pm
