Home > General > Side Step Trim Falling Off :(
rick280688
Anyone had any issues with the side step running board trim falling off? Sad I cannot seem to find a fix for this issue and don't really fancy having to buy brand new running boards just for the trim.
I have still got the trim as its holding on by 1 of the fixing, but will be falling off within the next few days i think.
Post #590316 Tue Nov 12 2019 6:45pm
Tyrefitter
Which RRS have you got,the RRS2 trim is only held on by 7-8 rivets but if it’s the early model I can’t remember how they are held on.Some I bought for my14 some of the rivets corroded & I nearly lost it but before it fell off a got some rivets & fastened it back on. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #590317 Tue Nov 12 2019 6:53pm
rick280688
I have got a 2010 TDV8 , not to sure how they are fitted to be fair, just know that its falling off Sad , can you post some pictures of how yours is fitted please. I would post some of mine but its currently in the garage getting the alloy wheels refurbed. Only owned her for 9 months.
Post #590320 Tue Nov 12 2019 7:01pm
Tyrefitter
Mine is a L494 not a L320 like yours but I’m sure someone on here took their trim off to clean it up so I’m sure they will post soon. Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #590322 Tue Nov 12 2019 7:08pm
gogsy1956
Had the same issue with mine, easiest option is to remove the step by taking off the smaller 5mm bolts, leaving the main support brackets attached to the car. Pop off the rubber tread, you will see where the old rivets have corroded so drill them out. Give the whole thing a coat of underseal or Hammerite, when dry put rubber back on and clamp the edge trim in place in the centre. Drill a new pilot hole and use short heavy duty self tapping screws and some oversize washers to secure it,, work your way to each end doing the same making sure the ends are pulled in nicely,,,, voila!!. 4 or 5 tappers should be enough to pull it in as it is quite springy hence the need for a small clamp to keep it in place when drilling. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #590324 Tue Nov 12 2019 7:21pm
Stevepd
Mine popped off at the the front on the drivers side. I drilled through mine and put a small bolt through it. You can’t really see it as it’s tucked away behind the wheel. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #590334 Tue Nov 12 2019 8:26pm
gogsy1956
If one rivet has popped the rest will be ready to go,, the only way to fix it properly is to take the step off and put all new fixings in 2010 RRS, TDV8
22" overfinch
Post #590336 Tue Nov 12 2019 8:45pm
rick280688
Thanks Guys, Has anyone got any picture they could post for me....
Post #590337 Tue Nov 12 2019 8:51pm
Ash3
Had a disco 3 ..same thing happened..nought a rivet set and tool and riveted it back on..unfortunately dont have photos. But I'm sure it can be riveted back.
Post #590347 Tue Nov 12 2019 11:34pm
Eaters
Is it worth using stainless steel self tappers to prevent corrosion in the future? Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #590355 Wed Nov 13 2019 7:59am
CornishRob
United Kingdom 2006 Range Rover Sport TDV6 HSE Sumatra Black
Yep, had to re-rivet mine a couple of times now. I don't think the standard allow rivets last very long, galvanic corrosion is at work I think. I meant to remove my side steps in the summer, and sort them properly, but didn't. I'll probably now have to do fix them when it's -5 Big Cry
A couple of pics ...
Post #590769 Thu Nov 21 2019 10:13pm
gogsy1956
Eaters,, I did actually use stainless tappers and washers, certainly a good idea if you want it to last 2010 RRS, TDV8
22" overfinch
Post #590820 Fri Nov 22 2019 3:10pm
Eaters
Thumbs Up Thumbs Up Robin
Gone:
MGZTT 190 2.5
Post #590824 Fri Nov 22 2019 3:58pm
Xstyle
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Lux Santorini Black
Same here...
My sidestep edge trim has also fallen off.
I've brushed off the rust and lose flakes from the set and cleaned up the trim itself too on the inside.
Will I have to drill out the rivet from the trim?
7 of 8 rivets are still in the trim, but obviously they have no heads.
What rivets are needed? Any links please?
Thanks!
Post #624095 Sun May 08 2022 6:18pm
karlos01
VPLGP0230 if I remember correctly this is the part number for the rivets for the side step
https://www.johncraddockltd.co.uk/vplgp023...g-kit.html
Post #624099 Sun May 08 2022 8:00pm
