Home > Maintenance & Modifications > Suspension dropped overnight - front wheels only. |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1138 |
I'd have a look at your front valve block Hugh. Drop the offside front wheel arch liner and you'll see it. Take it out, disassemble, give it a good clean out and lube up or renew the o-rings. Kev
Sun Oct 27 2019 10:46pm |
HughN Member Since: 10 Sep 2017 Location: Near Llanybydder Posts: 651 |
Mon Oct 28 2019 8:21am |
aljo Member Since: 13 Jun 2006 Location: West Sussex Posts: 3243 |
I had the same problem previously and as kev says check the valve block , I changed the front valve block with a new one and all back to normal
Mon Oct 28 2019 6:06pm |
Ace. I'll dig out the heavy-duty stands. I don't want a heavy car dropping on me - again. |
Mon Oct 28 2019 6:16pm |
I thought I'd bite the bullet and change the valve-block. The car had a new pump before I bought it and I couldn't help wondering whether there were bits of desiccant in it. Bumper-off, cracked the joints and walked away ... swapped it over and bumper back on. So far, so good: it hasn't dropped and the pump runs for less than ten seconds when I start the car after 24 hrs - better than the minute or so before the valve-block was changed, and much better than the four minutes it took with a leaky reservoir.
Sun Nov 10 2019 9:27pm |
Glad you got it sorted Hugh Kev
Sun Nov 10 2019 10:24pm |
