![]() | Home > Maintenance & Modifications > L320 Wheel Arch Edge Protectors |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5079 ![]() ![]() ![]() |
Did have some pictures of these in My Gallery but may have deleted them, will see if I can find them again.
Autobiography1969 Member Since: 17 Sep 2018 Location: S/E Posts: 475 ![]() ![]() |
This is interesting as I think mine had a set of splash guards fitted at some point,
Quick shot off rear one, can take better one's later if needed, 28 degrees here so just off to beach. |
Thanks Col,
No rear one's in the wrong place, should be on the wing/quarter panel not the bumper.
Of course the bumper is plastic so wont rust,,
Your a real star Col, |
No problem, glad to help and doesn't actualy cost anything. |
Mine were missing on the rear when I bought the car. When I bought a new pair, I couldn't get them to sit correctly on the arch (parallel with the metal without sagging) so I ended up leaving them off. Let us know how you get on with fitting. Kev
Strange, fitted several sets of these and never had a issue, just made sure they were trimmed to exact length required.
I priced some up for mine a few months back. Not cheap and couldn’t identify the original manufacturer to buy(what I assume to be) an off the shelf roll. 2019 5.0 SC SVA (Current)
This is what you need, exactly same stuff as the Sport except 20 quid cheaper a set and you get Six pieces instead of Four and cut right will do the whole car twice, as only generally lasts a couple of years or so, although mine have been on nearly Four years now.
I got mine from our friends at Duckworth-land-rover,,
